[snappyHexMesh] SnappyHexMesh arbitary meshing |
March 11, 2019, 09:59 |
shantanu mandhane
Rep Power: 8 |
Hello foamers,
I am facing an issue with snappyHexMesh for creating the mesh. I am getting multiple wierd/arbitary lines in the mesh and it has created tons of singular point due to which my simulation is crashing. Please help. Thanks in advance
Regards! Shantanu |
March 12, 2019, 13:50 |
shantanu mandhane
Rep Power: 8 |
I am receiving arbitrary mesh every time I run the same sHM code.
Is it normal to observe such defects? Also, would this mesh create further errors?
Regards! Shantanu |
March 12, 2019, 19:14 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I suspect that what you are seeing isn't real, namely that it's part of the polyhedral decomposition and not part of the original mesh. Follow the instructions given here: https://openfoamwiki.net/index.php/F...is_in_ParaView - to properly see the real mesh.
March 13, 2019, 06:53 |
shantanu mandhane
Rep Power: 8 |
okay! But before using sHM I created the mesh with blockMesh which was symmetric in yz-plane, then why would the refined cells come out of the plane of symmetry?
Regards! Shantanu |
March 13, 2019, 10:37 |
anonymous
Rep Power: 14 |
Because there is no reason to stay in plane (only if you have a constrain), and maybe during the smoothing process the x coordinate which is 0 for example becomes 1e-10, which is still 0. Or it is just simply a numerical error since 0 is never (i know there are some cases when 0 is 0) 0 exactly when you use floating point numbers.
Or as wyldcat mentioned it is simply a visualization "error". |
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials | denbjornen | OpenFOAM Meshing & Mesh Conversion | 1 | May 25, 2020 12:14 |
Map of this Meshing (sub-)Forum | wyldckat | OpenFOAM Meshing & Mesh Conversion | 0 | April 27, 2019 10:33 |
[snappyHexMesh] Meshing Naca0012 with snappyHexMesh | kasimirXV | OpenFOAM Meshing & Mesh Conversion | 10 | May 11, 2016 00:04 |
[snappyHexMesh] Problem Meshing a V-notch Weir with snappyHexMesh | kflora | OpenFOAM Meshing & Mesh Conversion | 11 | December 19, 2011 02:58 |
[snappyHexMesh] Meshing a sphere with snappyHexMesh | Cyberholmes | OpenFOAM Meshing & Mesh Conversion | 2 | July 19, 2011 17:46 |
