Brett
Rep Power: 14 ![]() |
Hey all,
I'm new to OpenFOAM and just making my way through the literature, tutorials etc.... Does anyone have any comment as to how to incorporate inflation, proximity and curvature size functions into openfoam? Much appreciated. Brett |
anonymous
Hi!
In SHm you can use feature angle as a curvature related refinement. For the proximity I think there is no option but you can use gap detection so you can automatically detect small gaps. If you have a really high angle between 2 surfaces, for example you mesh a wing(not the fluid but the wing itself) at the trailing edge you have 2 surfaces with a high angle. SHm will detect it as a "gap" so automatic refinement will be also done in these cases. If you are on the other side of the domain (fluid), then then you have to use the feature refinement. |
Brett
Thanks simrego!
I've been having some troubles with sHM. At the moment I'm trying to mesh an airfoil within a 3D domain where the foil edges dont touch the sides of the domain. Do you know of any example sHMDict files that could be a good template? |
anonymous
In the tutorials there is a mesh folder and a SHM folder in it where you can find examples, or check the motorBike tutorial.
Depending on the version you are using some explanation can be found here: OFv6 (FOUNDATION version): https://cfd.direct/openfoam/user-gui...snappyhexmesh/ or v1812 (esi group version): https://openfoam.com/documentation/g...pyhexmesh.html What works in OF 6 it is usually also working in the esi version, but not vice-versa. And the esi version has more functionality (I think gap detection is not implemented in OF6 but I'm not 100% sure, also different mesh smoothing for layer insertion, etc.). |
DPM simulation-Restrictions on the mesh size to particle size ratio? | cryabroad | Fluent Multiphase | 5 | June 16, 2022 01:51 |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Mesh refinement with Field Functions - error | Dan Chambers | STAR-CCM+ | 7 | January 30, 2014 08:01 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
