March 6, 2019, 11:17 |
snappyHexMesh question
Kyriakos Paso
Rep Power: 8 |
Hello everyone!
I have a question about the snappyHexMesh utility! I need to mesh a fluid region, where inside it there is a cylinder. I use snappyHexMesh for refining, but I need to keep both cylinder and fluid domains, for calculating temperatures in them. How can I do it? Isn't it compulsory to keep one region, defining it in the locationInMesh point? Thank you in advance! |
March 6, 2019, 13:36 |
Rep Power: 9 |
Hi KyriakosPaso,
have a look at https://openfoamwiki.net/index.php/S...-region_meshes and http://voluntary.holzmann-cfd.de/ope...region-meshing. Kind regards, Krapf |
March 7, 2019, 14:49 |
Kyriakos Paso
Rep Power: 8 |
That's exactly what I was searching!
Thank you Krapf! |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 07:01 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 03:55 |
[snappyHexMesh] Snappyhexmesh - simple question. | atareen64 | OpenFOAM Meshing & Mesh Conversion | 0 | March 16, 2011 15:02 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 03:09 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 08:08 |
