[mesh manipulation] mergePatchPairs after running blockMesh
Old   March 6, 2019, 08:57
Default mergePatchPairs after running blockMesh
Ashish Magar
ashishmagar600 is on a distinguished road
I am trying to mesh with an interface between two blocks having different mesh sizes.
I learned to use mergePatchPairs for joining them, but the cells created at the interface are not that clean, and the whole point of using blockMesh is lost.
Is there any method of using mergePatchPairs after running blockMesh? So that I could refine the coarser cells at the interface (by refineHexMesh), and then later use mergePatchPairs?
Thanks,
Magar
ashishmagar600 is offline   Reply With Quote
Old   March 7, 2019, 23:10
Antimony is on a distinguished road
What you could do is to mesh the two blocks separately and then merge & stitch them using mergeMeshes and stitchMesh. Not sure if that is a solution you are looking for.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   March 8, 2019, 05:15
Ashish Magar
This might work.
Thanks
[blockMesh] blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions pythag0ra5 OpenFOAM Meshing & Mesh Conversion 1 September 19, 2020 15:38
[blockMesh] errors in topology while running 'blockMesh' shimakasaei OpenFOAM Meshing & Mesh Conversion 2 February 15, 2018 06:56
[blockMesh] Error running blockMesh with mergePatchPairs on OF2.4.0 deepbandivadekar OpenFOAM Meshing & Mesh Conversion 1 November 25, 2017 15:50
[blockMesh] Problems using mergePatchPairs Peter83 OpenFOAM Meshing & Mesh Conversion 11 November 19, 2014 03:34
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 09:37
