[Gmsh] gmshToFoam killed on its own
Old   February 27, 2019, 07:37
Default gmshToFoam killed on its own
yuwen zhang
yuwen zhang is on a distinguished road
Hello there, I am a beginner to openFoam and GMSH. I am working on a 3D simulation of E387 wing at the moment. I have been given the coordinate points and from there I create the 2D surface and the extrusion of the 2D surface becomes my 3D wing. For the meshing, I used a C-grid and it is created from forming 2 quarter circle and rotate 90 degrees, followed by extrusion using the rotated surfaces.
I have created a coarse grid and the mesh is shown below,
I then exported the msh to openFoam, and after running gmshToFoam command, it killed itself during the progress,
" Mapping region 1 to Foam patch 0
Mapping region 2 to Foam patch 1
Mapping region 3 to Foam patch 2
Mapping region 4 to Foam cellZone 0
Cells:
total:4735955
hex :0
prism:0
pyr :0
tet :4735955
CellZones:
Zone Size
0 4735955
Skipping tag at line 5564051
Patch 0 gets name Symmetry
Patch 1 gets name Farfield
Patch 2 gets name Airfoil
Killed
OpenFOAM-6(520) "
I have attached both my geo files to create the mesh, and the openfoam 0, constant and system files below for your reference.
Please enlighten me what could be the reason for this issue and how can I solve it ? Thank you in advance !
Archive 2.zip (geo files)
Archive.zip (openfoam)
yuwen zhang is offline   Reply With Quote
Old   April 18, 2019, 16:29
Panos Koniavitis
PanosK is on a distinguished road
Hi there, I am kind of fighting with the same problem. I am trying to model a heat exchange pack and receiving problems when converting the .msh file with gmshToFoam. Could you upload your .msh file as well?
Best,
Panos
--------UPDATE ------------
Problem is now solved. The reason behind the error was one blank line at the very end of my *.msh file.
PanosK is offline   Reply With Quote
gmshtofoa 3d fail
Process killed unexpectedly and without any apparent reason amh@inventas.no OpenFOAM Running, Solving & CFD 2 January 19, 2024 03:15
[Gmsh] New version of gmshToFoam? stootoon OpenFOAM Meshing & Mesh Conversion 7 February 14, 2022 10:01
[Gmsh] gmshToFoam problem. nilashansen OpenFOAM Meshing & Mesh Conversion 11 June 5, 2016 11:45
[Gmsh] Cell to node connectivity after 'gmshToFoam' Jibran OpenFOAM Meshing & Mesh Conversion 1 June 8, 2015 10:09
[Gmsh] gmshToFoam command mvinassa OpenFOAM Meshing & Mesh Conversion 1 April 25, 2014 08:36
