[mesh manipulation] 2D polyDualMesh
Old   February 3, 2019, 15:01
Default 2D polyDualMesh
Reviewer #2
randolph is on a distinguished road
I was trying to follow the tutorial of polyDualMesh for 2D application (https://openfoamwiki.net/index.php/PolyDualMesh). However, I always ended with some bizarre mesh near the sharp angle (see attachment). I play around with the angle in combinePatchFaces, but no luck.
Thanks,
Rdf
File Type: png Screenshot from 2019-02-03 14-00-39.png (12.6 KB, 19 views)
randolph is offline   Reply With Quote
Old   February 19, 2019, 11:36
Reviewer #2
For the future reference, if you generate the poly mesh directly by gmsh, you can avoid this problem.
[mesh manipulation] problem using polyDualMesh Rebecca513 OpenFOAM Meshing & Mesh Conversion 10 March 4, 2020 13:53
[mesh manipulation] Sharp edge problem on concave patches using polyDualMesh without error keepfit OpenFOAM Meshing & Mesh Conversion 1 November 25, 2014 15:28
[snappyHexMesh] polyDualMesh -- Error kingmaker OpenFOAM Meshing & Mesh Conversion 4 November 22, 2013 05:33
[mesh manipulation] polyDualMesh edges between patches maninthemail OpenFOAM Meshing & Mesh Conversion 1 May 22, 2012 14:15
[mesh manipulation] polyDualMesh and volume calculation... jbf OpenFOAM Meshing & Mesh Conversion 2 September 15, 2009 19:37
