[snappyHexMesh] SnappyHexMesh for adding circle inlet |
February 1, 2019, 00:37 |
Kyriakos Paso
Rep Power: 8 |
Hello.
I have the geometry that is shown in the image below, and I need to add 4 circle inlets at the upper side of the cylinder. I have tried to use topoSet and createPatch utilities, but the result is not satisfying, due to the fact that in this mesh is impossible to create a circle. I have read in previous threads, that snappyHexMesh utility could be appropriate for my problem, but i don't know how it could help me? What .stl should I use, cylinders? Does anyone have any idea that could help me? Thank you in advance! |
February 1, 2019, 18:21 |
Luis Eduardo
Rep Power: 15 |
You can use SnappyHexMesh to refine the mesh in the region you want to use topoSet. There are two tutorials that can help you: https://github.com/OpenFOAM/OpenFOAM...Foam/rotorDisk https://github.com/OpenFOAM/OpenFOAM.../turbineSiting In the second one you can use searchableCylinder instead of searchableBox. Give it a try! =) Best Regards, Luis |
February 2, 2019, 21:59 |
Kyriakos Paso
Rep Power: 8 |
I'll try it!
Thanks a lot lbec!! Last edited by KyriakosPaso; February 4, 2019 at 02:09. |
February 4, 2019, 02:09 |
Kyriakos Paso
Rep Power: 8 |
I have a question. When i define a searchableCylinder in my mesh, and set refineRegions on level 6, shouldn't it be created a cylindrical mesh inside my mesh?
I tried it and i saw no difference in my mesh! |
February 4, 2019, 02:25 |
Luis Eduardo
Rep Power: 15 |
What searchableCylinder does is to find the cells inside this region and apply the refinement level you choose, but you may get different results depending on how you define the cylinder.
Try using a big cylinder to see if you have any refinement, maybe you are defining a small or thin cylinder in a very coarse mesh, which can not work depending on the case. |
February 4, 2019, 13:39 |
Kyriakos Paso
Rep Power: 8 |
May you have some time to examine my blockMeshDict and my snappyHexMeshDIct, because I tried it also for big cylinders but I found no progress.
February 4, 2019, 23:37 |
Luis Eduardo
Rep Power: 15 |
Sure, just send me your case folder and I can try here.
setting the correct format of nonuniform List<vector> for inlet in 0 Folder | cfdonline2mohsen | OpenFOAM Running, Solving & CFD | 8 | July 18, 2019 09:03 |
K-Omega-Epsilon BCs for suction inlet | CFDBro | OpenFOAM Running, Solving & CFD | 0 | March 27, 2018 19:28 |
multiphaseInterfoam non-constant inlet | kaaja | OpenFOAM Running, Solving & CFD | 4 | February 23, 2018 03:04 |
snappyhexmesh inlet divergence | olhe0002 | OpenFOAM Running, Solving & CFD | 1 | November 27, 2009 13:39 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 19:42 |
