[snappyHexMesh] Checking surface conformity
Old   January 25, 2019, 09:29
Default Checking surface conformity
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
Hello.
Is there a tool that would check if mesh points all lie on the meshed surfaces? sHM often produces artifacts where refinement level changes; these then cause problems on AMI patches and so on. I can check that visually but if I needed to work on a headless server it would be nice to be able to check it with a command-line tool...
Thanks!
kandelabr is offline   Reply With Quote
[OpenFOAM.com] Installing on Ubuntu 18.04 samiam1000 OpenFOAM Installation 11 April 27, 2020 01:01
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[GAMBIT] Problem with interior faces miro2000 ANSYS Meshing & Geometry 11 August 24, 2013 15:00
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
