[Commercial meshers] Error in converting mesh from cfx4tofoam Can you please help me?! |
January 7, 2019, 09:28 |
Os
Rep Power: 9 |
hey guys ,
I am new with openFoam , I ve created a mesh via ICEM and exported it asfor CFX4 (.geo) once i open openfoam and make the order cfx4ToFoam I get this error message and i cant run paraFoam & to see my mesh. Create time Reading blocks Reading patch definitions Reading block glueing information Reading block points block 0 is a right-handed block block 1 is a right-handed block block 2 is a right-handed block block 3 is a right-handed block block 4 is a right-handed block block 5 is a right-handed block block 6 is a right-handed block block 7 is a right-handed block block 8 is a right-handed block block 9 is a right-handed block Calculating block offsets Assembling patches Merging points . Creating points Creating cells Creating boundary patches CFX patch 28, of type WALL, name TOP converted into OpenFOAM patch 0 type wall. CFX patch 29, of type WALL, name TOP already exists as OpenFOAM patch 0. Adding faces. CFX patch 30, of type WALL, name TOP already exists as OpenFOAM patch 0. Adding faces. CFX patch 31, of type WALL, name TOP already exists as OpenFOAM patch 0. Adding faces. CFX patch 32, of type WALL, name TOP already exists as OpenFOAM patch 0. Adding faces. CFX patch 33, of type WALL, name AIRFOIL converted into OpenFOAM patch 1 type wall. CFX patch 34, of type WALL, name AIRFOIL already exists as OpenFOAM patch 1. Adding faces. CFX patch 35, of type WALL, name AIRFOIL already exists as OpenFOAM patch 1. Adding faces. Default patch type set to wall --> FOAM Warning : From function polyMesh:olyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 903 Found 374976 undefined faces in mesh; adding to default patch. Writing polyMesh End Can you please Tell me What is the Problem and How Can i Resolve it?! |
January 8, 2019, 23:01 |
Rep Power: 16 |
Based on the log, there is no error message, just a warning. The warning simply tells you that OF put boundary faces it couldn't associate a name with into a patch called "defaultFaces" or "default" or something similar. When you try to run paraFoam what error do you run into? Also, in order to view a OF case in Paraview, you can create an empty .foam file and open that in Paraview. Hope this helps. Cheers, Antimony |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
