[snappyHexMesh] Motorbike example: Failed 1 mesh checks |
December 10, 2018, 02:05 |
hui
Rep Power: 8 |
Hi Experts,
I have run Openfoam motorbike example on my instance and when checking mesh have got the error that "Failed 1 mesh checks". Could you please help me check the root cause for this mesh? I couldn't understand why the mesh was wrong. The steps to reproduce the error that: 1. cp -r $FOAM_TUTORIALS/incompressible/simpleFoam/motorBike . 2. Run allrun script: Code:
[openfoam@testopenfoammove run]# cd motorBike [openfoam@testopenfoammove motorBike]# ./Allrun Running surfaceFeatureExtract on /home/openfoam/OpenFOAM/root-v1806/run/motorBike Running blockMesh on /home/openfoam/OpenFOAM/root-v1806/run/motorBike Running decomposePar on /home/openfoam/OpenFOAM/root-v1806/run/motorBike Running snappyHexMesh in parallel on /home/openfoam/OpenFOAM/root-v1806/run/motorBike using 6 processes Running patchSummary in parallel on/home/openfoam/OpenFOAM/root-v1806/run/motorBike using 6 processes Running potentialFoam in parallel on /home/openfoam/OpenFOAM/root-v1806/run/motorBike using 6 processes Running simpleFoam in parallel on /home/openfoam/OpenFOAM/root-v1806/run/motorBike using 6 processes Running reconstructParMesh on /home/openfoam/OpenFOAM/root-v1806/run/motorBike Running reconstructPar on /home/openfoam/OpenFOAM/root-v1806/run/motorBike Code:
[openfoam@testopenfoammove motorBike]$ checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1806 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1806 Arch : "LSB;label=32;scalar=64" Exec : checkMesh Date : Dec 10 2018 Time : 02:06:27 Host : "testopenfoammove" PID : 7852 I/O : uncollated Case : /home/openfoam/OpenFOAM/openfoam-v1806/run/motorBike nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 500 Time = 500 Mesh stats points: 405037 faces: 1104871 internal faces: 1054763 cells: 352592 faces per cell: 6.12502 boundary patches: 72 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 307275 prisms: 7321 wedges: 988 pyramids: 3 tet wedges: 1763 tetrahedra: 58 polyhedra: 35184 Breakdown of polyhedra by number of faces: faces number of cells 4 3955 5 6547 6 5481 7 3023 8 1311 9 10609 10 13 11 6 12 2334 13 3 14 1 15 1633 17 1 18 265 21 2 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology frontAndBack 360 420 ok (non-closed singly connected) inlet 72 90 ok (non-closed singly connected) outlet 72 90 ok (non-closed singly connected) lowerWall 5349 5677 ok (non-closed singly connected) upperWall 160 189 ok (non-closed singly connected) motorBike_frt-fairing:001%1 5309 9910 multiply connected (shared edge) motorBike_windshield:002%2 50 83 ok (non-closed singly connected) motorBike_rr-wh-rim:005%5 127 219 ok (non-closed singly connected) motorBike_rr-wh-rim:010%10 354 672 ok (non-closed singly connected) motorBike_fr-wh-rim:011%11 500 826 ok (non-closed singly connected) motorBike_fr-wh-brake-disk:012%12 46 88 ok (non-closed singly connected) motorBike_frame:016-shadow%13 102 224 ok (non-closed singly connected) motorBike_rear-susp:014%14 848 1508 ok (non-closed singly connected) motorBike_rear-susp:014-shadow%15 437 1175 ok (non-closed singly connected) motorBike_frame:016%16 65 173 ok (non-closed singly connected) motorBike_rr-wh-rim:005-shadow%17 62 164 ok (non-closed singly connected) motorBike_rr-wh-chain-hub:022%22 128 220 ok (non-closed singly connected) motorBike_rearseat%24 421 512 ok (non-closed singly connected) motorBike_frt-fairing%25 617 853 ok (non-closed singly connected) motorBike_windshield%26 372 815 ok (non-closed singly connected) motorBike_headlights%27 156 257 ok (non-closed singly connected) motorBike_driversseat%28 350 531 ok (non-closed singly connected) motorBike_rear-body%29 2051 2519 ok (non-closed singly connected) motorBike_fuel-tank%30 878 1219 ok (non-closed singly connected) motorBike_exhaust%31 2334 2994 ok (non-closed singly connected) motorBike_rr-wh-rim%32 1377 1741 ok (non-closed singly connected) motorBike_fr-mud-guard%33 637 1194 ok (non-closed singly connected) motorBike_fr-wh-rim%34 574 796 ok (non-closed singly connected) motorBike_fr-wh-brake-disk%35 428 687 ok (non-closed singly connected) motorBike_fr-brake-caliper%36 157 208 ok (non-closed singly connected) motorBike_fr-wh-tyre%37 1108 1550 ok (non-closed singly connected) motorBike_hbars%38 520 669 ok (non-closed singly connected) motorBike_fr-forks%39 1095 1459 ok (non-closed singly connected) motorBike_chain%40 457 570 ok (non-closed singly connected) motorBike_rr-wh-tyre%41 1846 2425 ok (non-closed singly connected) motorBike_square-dial%42 6 12 ok (non-closed singly connected) motorBike_round-dial%43 15 29 ok (non-closed singly connected) motorBike_dial-holder%44 88 133 ok (non-closed singly connected) motorBike_rear-susp%45 1725 2170 multiply connected (shared edge) motorBike_rear-brake-lights%46 54 87 ok (non-closed singly connected) motorBike_rear-light-bracket%47 158 207 ok (non-closed singly connected) motorBike_frame%48 2007 2455 ok (non-closed singly connected) motorBike_rear-mud-guard%49 635 1203 ok (non-closed singly connected) motorBike_rear-susp-spring-damp%50 91 193 ok (non-closed singly connected) motorBike_fairing-inner-plate%51 433 558 ok (non-closed singly connected) motorBike_clutch-housing%52 929 1113 ok (non-closed singly connected) motorBike_radiator%53 44 77 multiply connected (shared edge) motorBike_water-pipe%54 101 114 multiply connected (shared edge) motorBike_water-pump%55 73 99 ok (non-closed singly connected) motorBike_engine%56 2301 2575 ok (non-closed singly connected) motorBike_rear-shock-link%57 28 61 ok (non-closed singly connected) motorBike_rear-brake-fluid-pot-bracket%58 39 79 ok (non-closed singly connected) motorBike_rear-brake-fluid-pot%59 51 62 ok (non-closed singly connected) motorBike_footpeg%60 90 125 ok (non-closed singly connected) motorBike_rr-wh-chain-hub%61 127 241 ok (non-closed singly connected) motorBike_rear-brake-caliper%62 145 177 ok (non-closed singly connected) motorBike_rider-helmet%65 760 1002 ok (non-closed singly connected) motorBike_rider-visor%66 165 266 ok (non-closed singly connected) motorBike_rider-boots%67 1008 1332 ok (non-closed singly connected) motorBike_rider-gloves%68 309 398 ok (non-closed singly connected) motorBike_rider-body%69 4584 5790 multiply connected (shared edge) motorBike_frame:0%70 37 61 ok (non-closed singly connected) motorBike_frt-fairing:001-shadow%74 3285 8417 multiply connected (shared edge) motorBike_windshield-shadow%75 266 706 ok (non-closed singly connected) motorBike_fr-mud-guard-shadow%81 317 879 ok (non-closed singly connected) motorBike_fr-wh-brake-disk-shadow%83 209 480 ok (non-closed singly connected) motorBike_rear-mud-guard-shadow%84 420 1052 ok (non-closed singly connected) motorBike_rear-susp-spring-damp-shadow%85 57 157 ok (non-closed singly connected) motorBike_radiator-shadow%86 28 61 ok (non-closed singly connected) motorBike_rear-shock-link-shadow%87 8 24 ok (non-closed singly connected) motorBike_rear-brake-fluid-pot-bracket-shadow%88 27 66 ok (non-closed singly connected) motorBike_rr-wh-chain-hub-shadow%89 69 185 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. <<Writing 16 conflicting points to set nonManifoldPoints Checking basic cellZone addressing... No cellZones found. Checking geometry... Overall domain bounding box (-5 -4 0) (15 4 8) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (3.89779e-18 1.03836e-16 -8.98276e-16) OK. Max cell openness = 9.34416e-16 OK. Max aspect ratio = 41.1396 OK. Minimum face area = 7.24969e-07. Maximum face area = 1.01339. Face area magnitudes OK. Min volume = 9.82386e-09. Max volume = 1.00376. Total volume = 1279.67. Cell volumes OK. Mesh non-orthogonality Max: 64.9585 average: 9.91962 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 10.2712, 11 highly skew faces detected which may impair the quality of the results <<Writing 11 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End |
December 11, 2018, 05:24 |
Hrvoje Jasak
Rep Power: 33 |
You can safely proceed - the mesh is fine. The checkMesh utility is very strict and the code will run fine on this mesh. Good luck, Hrvoje
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
December 11, 2018, 08:54 |
hui
Rep Power: 8 |
motorbike tutorial, openfoam |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[blockMesh] Failed 1 Mesh checks !! ? | T.D. | OpenFOAM Meshing & Mesh Conversion | 3 | February 24, 2011 18:39 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 10:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
