[blockMesh] Wierd behaviour of blockMesh creating axis in wedge
Old   December 4, 2018, 07:17
Default Wierd behaviour of blockMesh creating axis in wedge
Robert Castilla
rcastilla is on a distinguished road
Hi, everybody,
I am facing a weird behavior of blockMesh that is puzzling me .
I have vortices, a block and the axis patch defined in this way:
convertToMeters 0.001;
vertices
    (              49   1.37369130467505 -0.059976657627337 )
    (              57   1.37369130467505 -0.059976657627337 )
    (              49                 0                  0 )
    (              57                  0                  0 )
    (              49   1.37369130467505  0.059976657627337 )
    (              57   1.37369130467505  0.059976657627337 )
edges
blocks
    hex (2 3 1 0 2 3 5 4) b2 (25 25 1) simpleGrading (1 1 1)
boundary
    axis
        type empty;
        faces
            (2 3 3 2)
everything is ok, and the axis is created correctly;
Patches
  patch 0 (start: 1200 size: 0) name: axis
  patch 1 (start: 1200 size: 1325) name: defaultFaces
BUT if I change only the x-coordinate of the first axis vertex:
vertices
    (              49.91                 0                  0 )
    (              57                  0                  0 )
blockMesh creates 2 faces in the axis patch.
Patches
  patch 0 (start: 1200 size: 2) name: axis
  patch 1 (start: 1202 size: 1325) name: defaultFaces
These faces are, approx, in the middle of the axis and have zero area. And, of course, it avoids to run any simulation.
Also, it depends of discretization as well. If the 25 cells are replaced by 26, the mesh is correct again.
Does have anybody any clue about the reason of this behavior? How to avoid it? Is it a bug of blockMesh?
Looking forward for your comments.
Best regards
Robert
rcastilla is offline   Reply With Quote
Old   December 4, 2018, 07:24
Robert Castilla
I have seen now that there is a similar issue, 3 years old, in the OF issue tracking system
https://bugs.openfoam.org/view.php?id=1443#c3970
And it is marked by solved, but I cannot find the solution...
Best regards
Robert
[blockMesh] blockMesh coordinate system pardoa OpenFOAM Meshing & Mesh Conversion 5 October 23, 2023 14:29
rhoPimpleFoam hardship petrus OpenFOAM Running, Solving & CFD 0 October 7, 2016 03:41
[blockMesh] Fatal Error at blockMesh Generation - wedge hiasl OpenFOAM Meshing & Mesh Conversion 1 October 17, 2012 10:47
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Trouble with blockMesh kupiainen OpenFOAM Meshing & Mesh Conversion 40 January 10, 2009 18:44
