[Gmsh] GMSH only one corner of hex mesh on axis line
Old   November 6, 2018, 11:51
Default GMSH only one corner of hex mesh on axis line
krzychu111 is on a distinguished road
when I'm creating axisymmetric hex mesh. Because my shape has more than 5 corners I'm not able to use transfinite surface. So I'm limited to recombine surface. But this tool is not avoiding scenario when only one corner of single node is on axis [see picture] and this causes creating extra surfaces which is breaking the simulation.
How can I force the engine to put two corners of each node on axis line?
vehicle_diameter = 1;
tube_diameter = 8*vehicle_diameter;
vehicle_length = 5*vehicle_diameter;
tube_length = 3*vehicle_length;
vehicle_gridsize = 0.01;
far_gridsize = 0.25;
Mesh.Smoothing = 5;
ce = 1;
Point(ce) = {0,0,0,vehicle_gridsize};e1=ce;ce++;
Point(ce) = {vehicle_diameter/2,0,0,vehicle_gridsize};c1 = ce;ce++;
Point(ce) = {vehicle_diameter/2,vehicle_diameter/2,0,vehicle_gridsize};t1=ce;ce++;
Point(ce) = {vehicle_length-vehicle_diameter/2,vehicle_diameter/2,0,vehicle_gridsize};t2=ce;ce++;
Point(ce) = {vehicle_length-vehicle_diameter/2,tube_diameter/2,0,far_gridsize};c2 = ce;ce++;
Point(ce) = {-tube_length/2+vehicle_length/2,0,0,far_gridsize};i1=ce;ce++;
Point(ce) = {-tube_length/2+vehicle_length/2,tube_diameter/2,0,far_gridsize};i2=ce;ce++;
Point(ce) = {vehicle_length-vehicle_diameter/2,0,0,vehicle_gridsize};pr1=ce;ce++;
lns[]={};
tlns[]={};
Line(ce) = {i1,e1};        x1=ce;    lns[]+=ce;    ce++;
Circle(ce) = {e1,c1,t1};    x2=ce;    lns[]+=ce;    ce++;
Line(ce) = {t1,t2};        x3=ce;    lns[]+=ce;    ce++;
Line(ce) = {t2,c2};        x4=ce;    lns[]+=ce;    ce++;
Line(ce) = {c2,i2};        x5=ce;    lns[]+=ce;    ce++;
Line(ce) = {i2,i1};        x6=ce;    lns[]+=ce;    ce++;
Line(ce) = {i1,pr1};        x7=ce;            ce++;
Line(ce) = {pr1,c2};        x8=ce;            ce++;
Line Loop(ce) = lns[];ce++;
Plane Surface(ce) = ce-1;surf=ce;ce++;
//hex
Transfinite Curve{x7}=80;
Recombine Surface{surf}=25;
//Transfinite Line{x7,x8,x5,x6}=1;
//Transfinite Surface{surf};
//Transfinite Surface{surf}={6,4,5,7};
//TransfQuadTri{surf};
//Transfinite Volume{new_entities[1]};
Rotate {{1,0,0},{0,0,0},2.5*Pi/180.0}
    Surface{surf};
new_entities[] = Extrude {{1,0,0},{0,0,0},-5*Pi/180.0}
    Surface{surf};
    Layers{1};
    Recombine;
Physical Surface("ring") = {new_entities[{2:3}]};
Physical Surface("tunnel") = {new_entities[5]};
Physical Surface("outlet") = {new_entities[4]};
Physical Surface("inlet") = {new_entities[6]};
Physical Surface("wedge0") = {surf};
Physical Surface("wedge1") = {new_entities[0]};
Physical Volume("volume") = {new_entities[1]};
krzychu111 is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
GMSH - Very strange effect - Mesh elements deleted when saving Araist Mesh Generation & Pre-Processing 3 July 15, 2015 07:03
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
