[Other] Floating point exception with changed distance scale |
Muriel
Rep Power: 0 ![]() |
Hello!
I am creating a simulation of 2 rotating cylinders in a 2D rectangular tank. Everything successfully compiles when my blockMeshDict is on a meter scale. However, when I changed everything to the centimeter scale, which more accurately represents the real tank I am trying to simulate, I get a floating point exception error when I run pimpleFoam (blockMesh itself runs successfully). I’ve tried to figure out this out on my own for several days but I’m stumped. Any help would be greatly appreciated. My blockMesh code: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; vertices #codeStream { codeInclude #{ #include "pointField.H" #}; code #{ pointField points(38); points[0] = point(0.5, 0, -0.5); points[1] = point(1, 0, -0.5); points[2] = point(2, 0, -0.5); points[3] = point(2, 0.707107, -0.5); points[4] = point(0.707107, 0.707107, -0.5); points[5] = point(0.353553, 0.353553, -0.5); points[6] = point(2, 2, -0.5); points[7] = point(0.707107, 2, -0.5); points[8] = point(0, 2, -0.5); points[9] = point(0, 1, -0.5); points[10] = point(0, 0.5, -0.5); points[11] = point(-0.5, 0, -0.5); points[12] = point(-1, 0, -0.5); points[13] = point(-2, 0, -0.5); points[14] = point(-2, 0.707107, -0.5); points[15] = point(-0.707107, 0.707107, -0.5); points[16] = point(-0.353553, 0.353553, -0.5); points[17] = point(-2, 2, -0.5); points[18] = point(-0.707107, 2, -0.5); //cyl 2: add 4 to every x coordinate //bc of overlap, use 6, 3, and 2 where 17, 14 and 13 were used for cyl 1 points[19] = point(4.5, 0, -0.5); points[20] = point(5, 0, -0.5); points[21] = point(6, 0, -0.5); points[22] = point(6, 0.707107, -0.5); points[23] = point(4.707107, 0.707107, -0.5); points[24] = point(4.353553, 0.353553, -0.5); points[25] = point(6, 2, -0.5); points[26] = point(4.707107, 2, -0.5); points[27] = point(4, 2, -0.5); points[28] = point(4, 1, -0.5); points[29] = point(4, 0.5, -0.5); points[30] = point(3.5, 0, -0.5); points[31] = point(3, 0, -0.5); // points[32] = point(3, 0, -0.5); //points[33] = point(2, 0.707107, -0.5); points[34] = point(3.292829, 0.707107, -0.5); points[35] = point(3.646447, 0.353553, -0.5); points[36] = point(2, 2, -0.5); points[37] = point(3.292829, 2, -0.5); // Duplicate z points label sz = points.size(); points.setSize(2*sz); for (label i = 0; i < sz; i++) { const point& pt = points[i]; points[i+sz] = point(pt.x(), pt.y(), -pt.z()); } os << points; #}; }; blocks ( //cyl 1 hex (5 4 9 10 43 42 47 48) (10 10 1) simpleGrading (1 1 1) hex (0 1 4 5 38 39 42 43) (10 10 1) simpleGrading (1 1 1) hex (1 2 3 4 39 40 41 42) (20 10 1) simpleGrading (1 1 1) hex (4 3 6 7 42 41 44 45) (20 20 1) simpleGrading (1 1 1) hex (9 4 7 8 47 42 45 46) (10 20 1) simpleGrading (1 1 1) hex (15 16 10 9 53 54 48 47) (10 10 1) simpleGrading (1 1 1) hex (12 11 16 15 50 49 54 53) (10 10 1) simpleGrading (1 1 1) hex (13 12 15 14 51 50 53 52) (20 10 1) simpleGrading (1 1 1) hex (14 15 18 17 52 53 56 55) (20 20 1) simpleGrading (1 1 1) hex (15 9 8 18 53 47 46 56) (10 20 1) simpleGrading (1 1 1) //cyl 2 hex (24 23 28 29 62 61 66 67) (10 10 1) simpleGrading (1 1 1) hex (19 20 23 24 57 58 61 62) (10 10 1) simpleGrading (1 1 1) hex (20 21 22 23 58 59 60 61) (20 10 1) simpleGrading (1 1 1) hex (23 22 25 26 61 60 63 64) (20 20 1) simpleGrading (1 1 1) hex (28 23 26 27 66 61 64 65) (10 20 1) simpleGrading (1 1 1) hex (34 35 29 28 72 73 67 66) (10 10 1) simpleGrading (1 1 1) hex (31 30 35 34 69 68 73 72) (10 10 1) simpleGrading (1 1 1) hex (2 31 34 3 40 69 72 41) (20 10 1) simpleGrading (1 1 1) hex (3 34 37 6 41 72 75 44) (20 20 1) simpleGrading (1 1 1) hex (34 28 27 37 72 66 65 75) (10 20 1) simpleGrading (1 1 1) ); edges ( arc 0 5 (0.469846 0.17101 -0.5) arc 5 10 (0.17101 0.469846 -0.5) arc 1 4 (0.939693 0.34202 -0.5) arc 4 9 (0.34202 0.939693 -0.5) arc 38 43 (0.469846 0.17101 0.5) arc 43 48 (0.17101 0.469846 0.5) arc 39 42 (0.939693 0.34202 0.5) arc 42 47 (0.34202 0.939693 0.5) arc 11 16 (-0.469846 0.17101 -0.5) arc 16 10 (-0.17101 0.469846 -0.5) arc 12 15 (-0.939693 0.34202 -0.5) arc 15 9 (-0.34202 0.939693 -0.5) arc 49 54 (-0.469846 0.17101 0.5) arc 54 48 (-0.17101 0.469846 0.5) arc 50 53 (-0.939693 0.34202 0.5) arc 53 47 (-0.34202 0.939693 0.5) //cyl 2: add 4 to all x-coordinates arc 19 24 (4.469846 0.17101 -0.5) arc 24 29 (4.17101 0.469846 -0.5) arc 20 23 (4.939693 0.34202 -0.5) arc 23 28 (4.34202 0.939693 -0.5) arc 57 62 (4.469846 0.17101 0.5) arc 62 67 (4.17101 0.469846 0.5) arc 58 61 (4.939693 0.34202 0.5) arc 61 66 (4.34202 0.939693 0.5) arc 30 35 (3.530154 0.17101 -0.5) arc 35 29 (3.82899 0.469846 -0.5) arc 31 34 (3.060307 0.34202 -0.5) arc 34 28 (3.65798 0.939693 -0.5) arc 68 73 (3.530154 0.17101 0.5) arc 73 67 (3.82899 0.469846 0.5) arc 69 72 (3.060307 0.34202 0.5) arc 72 66 (3.65798 0.939693 0.5) ); boundary ( down { type symmetry; faces ( (0 1 39 38) (1 2 40 39) (12 11 49 50) (13 12 50 51) //cyl 2 (19 20 58 57) (20 21 59 58) (31 30 68 69) (2 31 69 40) ); } right { type wall; //replace with right cylinder faces ( (21 22 60 59) (22 25 63 60) ); } up { type wall; faces ( (7 8 46 45) (6 7 45 44) (8 18 56 46) (18 17 55 56) //cyl 2 (26 27 65 64) (25 26 64 63) (27 37 75 65) (37 6 44 75) ); } left { type wall; faces ( (14 13 51 52) (17 14 52 55) ); } cyl-1 { type wall; faces ( (10 5 43 48) (5 0 38 43) (16 10 48 54) (11 16 54 49) ); } cyl-2 { type wall; faces ( (29 24 62 67) (24 19 57 62) (35 29 67 73) (30 35 73 68) ); } ); mergePatchPairs ( ); Code:
PIMPLE: iteration 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 Foam::surfaceInterpolation::makeNonOrthDeltaCoeffs() const at ??:? #4 Foam::surfaceInterpolation::nonOrthDeltaCoeffs() const at ??:? #5 Foam::fv::correctedSnGrad<Foam::Vector<double> >::deltaCoeffs(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #6 Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #7 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #8 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #9 Foam::linearViscousStress<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::divDevRhoReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:? #10 Foam::IncompressibleTurbulenceModel<Foam::transportModel>::divDevReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:? #11 ? at ??:? #12 __libc_start_main in "/lib64/libc.so.6" #13 ? at ??:? [hawk-int:32378:0] Caught signal 8 (Floating point exception) ==== backtrace ==== 2 0x00000000000686ec mxm_handle_error() /var/tmp/OFED_topdir/BUILD/mxm-3.5.3093/src/mxm/util/debug/debug.c:641 3 0x0000000000068c3c mxm_error_signal_handler() /var/tmp/OFED_topdir/BUILD/mxm-3.5.3093/src/mxm/util/debug/debug.c:616 4 0x0000000000035250 killpg() ??:0 5 0x00000000000351d7 __GI_raise() :0 6 0x0000000000035250 killpg() ??:0 7 0x0000000000d05c6b _ZNK4Foam20surfaceInterpolation22makeNonOrthDeltaCoeffsEv() ??:0 8 0x0000000000d063c5 _ZNK4Foam20surfaceInterpolation18nonOrthDeltaCoeffsEv() ??:0 9 0x0000000001256f34 _ZNK4Foam2fv15correctedSnGradINS_6VectorIdEEE11deltaCoeffsERKNS_14GeometricFieldIS3_NS_12fvPatchFieldENS_7volMeshEEE() ??:0 10 0x00000000012f5baf _ZN4Foam2fv20gaussLaplacianSchemeINS_6VectorIdEEdE12fvmLaplacianERKNS_14GeometricFieldIdNS_13fvsPatchFieldENS_11surfaceMeshEEERKNS5_IS3_NS_12fvPatchFieldENS_7volMeshEEE() ??:0 11 0x0000000001300449 _ZN4Foam2fv15laplacianSchemeINS_6VectorIdEEdE12fvmLaplacianERKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEERKNS5_IS3_S6_S7_EE() ??:0 12 0x00000000000e363e _ZN4Foam3fvm9laplacianINS_6VectorIdEEdEENS_3tmpINS_8fvMatrixIT_EEEERKNS_14GeometricFieldIT0_NS_12fvPatchFieldENS_7volMeshEEERKNS9_IS6_SB_SC_EE() ??:0 13 0x00000000001625ac _ZNK4Foam19linearViscousStressINS_29IncompressibleTurbulenceModelINS_14transportModelEEEE13divDevRhoReffERNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEE() ??:0 14 0x00000000000a78cd _ZNK4Foam29IncompressibleTurbulenceModelINS_14transportModelEE10divDevReffERNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEE() ??:0 15 0x00000000004239cf main() ??:0 16 0x0000000000021b35 __libc_start_main() ??:0 17 0x000000000042546c _start() ??:0 =================== Floating point exception (core dumped) Thanks, Muriel |
blockmeshdict, floating point exception, surfaceinterpolation |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 16:23 |
Floating point exception error with small DeltaT | rassilon | OpenFOAM Running, Solving & CFD | 19 | September 2, 2009 07:39 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
