[blockMesh] FOAM Fatal Error when I want to make a patch in a semicircle |
October 31, 2018, 12:26 |
Alexandru Mihai
Hy guys,
I am new to OpenFoam and C++, I have to make an inlet patch for a semicircle section of an inside pipe. The semicircle pipe is comprised out of 4 blocks and it can be seen in the picture below with the chosen numbers. The problem is when I try to write them I do not know why is giving me the error that it can find neighbor cell faces. Here is the code. Can you help me out please? /*--------------------------------*- C++ -*----------------------------------*\ ========= | foam-extend-4.0: Open Source CFD \\ / F ield | URL: http://www.foam-extend.org \\ / O peration | \\ / A nd | OpenFOAM-6: The Open Source CFD Toolbox \\/ M anipulation | URL: https://openfoam.org \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant/polyMesh"; object blockMeshDict; } convertToMeters 0.001; vertices ( (0 0 -7.5) // point 0 as 4''' (750 0 -7.5) // point 1 as 5''' (750 7.5 -7.5) // point 2 & 1" & 6''' (0 7.5 -7.5) // point 3 & 0" & 7''' (0 0 7.5) // point 4 as 0' (750 0 7.5) // point 5 as 1' (750 7.5 7.5) // point 6 as 2' (0 7.5 7.5) // point 7 as 3' (0 0 22.5) // point 8 as 4' (750 0 22.5) // point 9 as 5' (750 15.9 15.9) // point 10 as 6' (0 15.9 15.9) // point 11 as 7' (750 15.9 -15.9) // point 12 as 2" & 2''' (0 15.9 -15.9) // point 13 as 3" & 3''' (0 0 -22.5) // point 14 as 0''' (750 0 -22.5) // point 15 as 1''' ); blocks ( // Order of points defines local coordinate system! hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1) hex (4 5 6 7 8 9 10 11) (10 10 10) simpleGrading (1 1 1) hex (3 2 12 13 7 6 10 11) (10 10 10) simpleGrading (1 1 1) hex (14 15 12 13 0 1 2 3) (10 10 10) simpleGrading (1 1 1) ); edges ( // We can bend existing block edges only! arc 8 11 (0 8.61 20.78) arc 9 10 (750 8.61 20.78) arc 11 13 (0 22.5 0) arc 10 12 (750 22.5 0) arc 13 14 (0 8.61 -20.78) arc 12 15 (750 8.61 -20.78) ); boundary ( // Boundaries are named geometrical boundaries for the boundary conditions. wall // boundary name { type wall; // 'wall' is a boundary where no flow can go through. faces ( (8 9 10 11) (11 10 12 13) (13 12 15 14) ); } cut // boundary name { type patch; // 'patch' is a general boundary where flow can go through. faces ( (9 8 4 5) (5 4 0 1) (1 0 14 15) ); } patch2 // boundary name { type patch; // 'patch' is a general boundary where flow can go through. faces ( (8 11 5 4) (4 5 3 0) (0 3 13 14) (13 3 5 11) ); } // Other boundary types are, for example, symmetry, cyclic etc. ); mergePatchPairs ( ); |
November 1, 2018, 03:42 |
Zander Meiring
Rep Power: 8 |
Please attach an image of the blocks you are trying to build, as well as the error that is outputted
November 3, 2018, 08:50 |
Alexandru Mihai
I managed to solve the error. It was a typo in my code. Please close this thread.
blockmesh, error, merge, semicircle |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 08:53 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
