[mesh manipulation] Incorrect (as I suppose) calculation of skewness by checkMesh
Old   October 31, 2018, 08:36
Question Incorrect (as I suppose) calculation of skewness by checkMesh
Kirils Surovovs
Kirils is on a distinguished road
Hello! Short summary of the problem: it seems that checkMesh utility calculates cell skewness incorrectly.
The more detailed description. I create a 2D mesh using the blockMeshDict from the attachment. Regular non-orthogonal mesh is created. I show an example in the attachment, but the mesh looks the same everywhere. When I run checkMesh, it says:
Max skewness = 1.825084 OK.
However, according to the code in the file OpenFOAM-2.1.1/src/meshTools/cellQuality
        scalar dOwn = mag
            (faceCtrs[faceI] - cellCtrs[own[faceI]]) & areas[faceI]
        )/mag(areas[faceI]);
        scalar dNei = mag
            (cellCtrs[nei[faceI]] - faceCtrs[faceI]) & areas[faceI]
        point faceIntersection =
          + (dOwn/(dOwn+dNei))*(cellCtrs[nei[faceI]] - cellCtrs[own[faceI]]);
        scalar skewness =
            mag(faceCtrs[faceI] - faceIntersection)
           /(mag(cellCtrs[nei[faceI]] - cellCtrs[own[faceI]]) + VSMALL);
and to the definition of skewness in this Wiki page (https://openfoamwiki.net/index.php/CheckMesh), the skewness value should be exactly zero, because every line that connects two cell centers goes exactly through the face center!
The same problem happens in all OpenFOAM versions. Does anyone have any idea why does it happen? I append also the whole case folder in the attachments, for easier replication. Just unzip it and run blockMesh and checkMesh.
Kirils is offline   Reply With Quote
checkmesh, skewness
Questions on Boundary Layer Spring Method for 3D Calculation didiean FLUENT 15 December 18, 2014 22:09
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Unsteady Statistics- incorrect calculation, etc. John FLUENT 0 June 27, 2007 20:04
Warning 097- AB Siemens 6 November 15, 2004 05:41
