[Other] Interface problem from Starccm+ to OpenFoam
Old   October 30, 2018, 13:16
Exclamation Interface problem from Starccm+ to OpenFoam
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello everybody,
I'm facing the following problem: I created a mesh with Starccm+ and I tried to convert it using ccmToFoam. The problem is that my original mesh contains interfaces (not miving), that connect different part of a pipe. If I tried to start a simulation OpenFoam asks me to set a boundary condition for the interface, that in the "boundaryRegion" file appears as "wall".
Here the error
Cannot find patchField entry for Interface0_1
How can I fix this problem?
Thanks for help,
best regards
FlyBob91 is offline   Reply With Quote
Old   October 31, 2018, 04:29
Björn
BjoernFoam is on a distinguished road
Hello Bob,
I am relatively new to OpenFOAM but willing to share what I have learned so far...
Have you tried to simply remove the corresponding entry in your boundary file?
Remember to also change the first line after the FoamFile header to your new number of boundaries.
BjoernFoam is offline   Reply With Quote
Old   October 31, 2018, 05:40
FlyBob91's Avatar
Originally Posted by BjoernFoam View Post
Hello Bob,
Hey Björn,
Thank you for the suggestion. I've just tried what you said and I was able to start the simulation but it stops at the first iteration, sign that somwthing wrong is still there.
Just another question. Should I remove the interface in both "boudnary" and "boundaryRegion" files?
Old   November 13, 2018, 07:02
Björn
Hello Bob,
please excuse my late reply, I forgot to subscribe and did not get a mail notification...
I don't think that the boundaryRegion file is of much concern to your simulation, if you dont use any boundary-regions in your 0-directory or any other files like the topoSetDict.
Could you run your simulation by now?
Another hint: I usualle get several "wall"- or even several "inlet"-patches when translating meshes to OpenFOAM. If they are written beneath each other you can easely merge your let's say "inlet-patch" by writing the manually calculated result of
startFace*FirstInletPatch - startFace*LastInletPatch + nFaces*LastInletPatch
in the line of
nFaces*FirstInletPatch
and deleting the by now unnecessary inlet-patches.
I usually also delete the inGroups line as i did not need it so far...
Also remember again to change the resulting amount of total patches within the first line after the header of the boundary file.
Best regards
Björn
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 05:36
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
