[snappyHexMesh] snappyHexMesh - cylinder appears as a square!
Old   October 18, 2018, 08:02
Default snappyHexMesh - cylinder appears as a square!
Chia
chia87 is on a distinguished road
hi all,
My cylinder which is exported using stl mesh,
however it appeared as a square,
I was wondering if is it because of my z-axis mesh in my blockmesh is defined as 1 mesh?
Sorry all am pretty new to snappyhexmesh
any help would be appreciated
chia87 is offline   Reply With Quote
Old   October 23, 2018, 22:41
Chia
correction my cylinder didnt even appear after I wrote the snappyHexMesh -overwrite
i did check my cylinder stl mesh seperately as attached in jpg format
1) surfaceFeatureExtract .. (as attached)
2) blockMesh (as attached)
3) snappyHexMesh -overwrite (as attached)
now when i open the paraFoam, I couldnt even see the cylinder!
I tried to mimic the motorBike tutorial, and going thru step by step but was futile,
Any help would be greatly appreciated
Aeroacoustic analysis of a 2d square cylinder busraeren FLUENT 2 March 17, 2018 06:54
VIV Square Cylinder lazze12 FLUENT 0 September 1, 2015 23:32
Force coefficients of a flow past a square cylinder new_flow Main CFD Forum 0 July 6, 2015 12:17
how to mesh cylinder inside the square duct kathir Siemens 1 August 1, 2006 09:44
solving airfoil like square cylinder problem? zonexo Main CFD Forum 1 May 27, 2006 16:16
