[Gmsh] Gmsh Boolean Subtraction on .stl Files |
October 5, 2018, 16:22 |
Fariba Mohammadi
I am trying to do Boolean subtraction on two surface meshes. My mesh files are in .stl format. In Gmsh, I tried to define each mesh as volume using Modules>Geometry>Elementary entities>Add>Volume. It created a .geo file containing my .stl file name as a command and used that as the script file. Then I merged both files and tried to do the Boolean subtraction. It is giving me the following error, Error: Unknown OpenCASCADE entity with dimension 3 with tag 1 Error: '', line 3: Could not apply boolean operator My script looks like this, Merge "left_ivc_vein.stl"; Surface Loop(1) = {1}; //+ Volume(1) = {1}; //+ Merge "left_ivc_filter.stl"; Surface Loop(2) = {2}; //+ Volume(2) = {2}; //+ SetFactory("OpenCASCADE"); BooleanDifference{ Volume{1}; }{ Volume{2}; Delete; } I am new to Gmsh and I am not sure what I am doing wrong here. Any help is greatly appreciated. |
Query regarding post processing of .dat and .stl files | bhargav4991 | Tecplot | 0 | December 2, 2016 08:20 |
[Gmsh] Boolean operation in Gmsh? | wwrfd | OpenFOAM Meshing & Mesh Conversion | 1 | August 17, 2011 10:46 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
How to read .stl files with gambit 2.0 ? | Lio | FLUENT | 6 | July 1, 2004 08:39 |
[making animations] fclose fails to close files? | Mika | FLUENT | 0 | March 30, 2001 09:19 |
