[snappyHexMesh] snappyHexMesh crashes unexpectedly
Old   September 26, 2018, 10:14
Default snappyHexMesh crashes unexpectedly
Sita Drost
sita is on a distinguished road
Hello everyone,
I'm using snappyHexMesh to mesh my geometry, which was going fine. I actually already had a mesh, which I wanted to tweak just a little further, so I edited my snappyHexMeshDict and re-ran snappyHexMesh. For some reason it then crashed, with the following error messages:
    From function Foam::labelListList Foam::hexRef8::setRefinement(const labelList&, Foam::polyTopoChange&)
    in file polyTopoChange/polyTopoChange/hexRef8/hexRef8.C at line 3725.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::hexRef8::setRefinement(Foam::List<int> const&, Foam::polyTopoChange&) at ??:?
#3  Foam::meshRefinement::refine(Foam::List<int> const&) at ??:?
#4  Foam::meshRefinement::refineAndBalance(Foam::string const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&, Foam::List<int> const&, double) at ??:?
#5  Foam::snappyRefineDriver::surfaceOnlyRefine(Foam::refinementParameters const&, int) at ??:?
#6  Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, Foam::dictionary const&) at ??:?
#7  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/snappyHexMesh"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/snappyHexMesh"
Aborted (core dumped)
Also, in my OpenFoam case directory, a file was then created called cell_23.obj.
So I thought perhaps I was asking too much and I reverted some of the changes I made in snappyHexMeshDict, but snappyHexMesh now keeps crashing, even on the version that I originally started with, which at first ran fine.
Does anyone have any idea what's going wrong here?
I'm using OpenFOAM 6 on Ubuntu 18.04, by the way.
Any help would be very much appreciated!
Sita
sita is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh crashes if nRelaxIter>0 kishore96 OpenFOAM Meshing & Mesh Conversion 11 August 31, 2017 08:42
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
potentialFoam & simpleFoam crashes after snappyhexmesh [parallel execution] pilot320 OpenFOAM Running, Solving & CFD 10 November 12, 2015 17:56
SnappyHexmesh crashes with many processes flami OpenFOAM Pre-Processing 10 July 18, 2012 17:29
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 13:48
