[snappyHexMesh] snappeyHexMesh wihtout STL geometry |
June 29, 2017, 11:05 |
Amod Kumar
Rep Power: 16 |
I went through the documents and links (but not all, it will take few weeks to me to understand), I have a small query. Can sHM be used without STL geometry data? I meant - let's consider an ellipse inside a rectangle for sake of demonstration. The elliptical geometry can be easily created in blockMeshDict. Now I want to use sHM instead of blockMesh to create a hexa-dominant mesh? Is it possible? Thank you for your attention! Regards, Amod |
[snappyHexMesh] What CAD software do you use to define STL surfaces? | Awak | OpenFOAM Meshing & Mesh Conversion | 11 | November 12, 2020 12:00 |
How to improve triangulation in my geometry ( STL) | Adam_PHD | CONVERGE | 2 | December 28, 2017 17:32 |
[ICEM] Work with imported STL geometry | KateEisenhower | ANSYS Meshing & Geometry | 2 | July 9, 2015 11:46 |
[ICEM] STL Geometry in ICEM | asal | ANSYS Meshing & Geometry | 3 | February 5, 2013 10:44 |
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS | kamran_kibria | ANSYS Meshing & Geometry | 0 | September 15, 2011 06:14 |
