[Other] Non-uniform meshing using hexahedra with third party algorithm
Old   August 10, 2018, 10:24
Default Non-uniform meshing using hexahedra with third party algorithm
Karsten
13Kartoffelbrei is on a distinguished road
Hi all,
I created a mesh using an algorithm from university. The idea was to implement a block-structured mesh (hexahedra as primitives) that refines towards the input geometry. Evidently this results in hanging nodes. When I visualized the mesh in paraview I have noticed that (instead of hanging nodes) polyhedral cells were created (see picture1).
Now my first question: is that the way how OpenFOAM treats hanging nodes, is this "ok"? (I got the suspicion the face areas were assigned to the wrong cell) Because actually I do not want these polyhedral cells for my fluid flow calculation...
So I did some "debugging":
I run checkMesh and the polyhedral cells gave an error (***Faces not in triangular order***) but after running renumberMesh it said that the Mesh was ok. However for a more complex case, for example when I have a sphere as input file, I get the error message ***Open cells found...***. So my second question is: Could this error be related to the hanging nodes or is there something else wrong with the meshing?
I am sorry for the long text, I know it is quite specific for what I am asking. In case there is something fundamentally wrong with this approach of non-uniform mesh refinement, let me know.
Best,
Kartoffelbrei
13Kartoffelbrei is offline   Reply With Quote
face area vector, hexa block, meshing 3d, non uniform mesh problem
wallHeatFlux utility for an incompressible case Mr.Jingles OpenFOAM Post-Processing 67 April 6, 2023 04:25
after 3 timesteps I always get "Floating Point Exception" knoedl1 OpenFOAM Running, Solving & CFD 18 January 25, 2015 12:56
simpleFoam Floating point error (Core Dumped) sam.ho OpenFOAM Running, Solving & CFD 2 December 31, 2013 07:57
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 03:31
rhoSimpleFoam claco OpenFOAM 7 April 20, 2010 05:32
