[snappyHexMesh] Overlapping cellZones in snappyHexMesh |
July 29, 2018, 02:11 |
Morteza
Rep Power: 8 |
I have a question about mesh generation with snappyHexMesh when there are multiple regions with mutual volume. I have generated concentric cylinders as separate STL files to give different levels in each region. I have assigned each of them a cellZone, shown in the figure (otherwise they will be removed). But after mesh generation with SHM, only the cylindrical cellZone which includes all cell zones (the biggest one) exist in the cellZones file in polyMesh folder as well as paraview, and other cellZones/patches are not available. As an example, the green patch shown in the image is not available. Is there any way to maintain all cell zones?
Thanks. |
cell zones, snappyhexmesh |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] SHM doesn't create cellZones for one region | Eko | OpenFOAM Meshing & Mesh Conversion | 10 | January 24, 2018 03:03 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 03:54 |
SnappyHexMesh not creating cellzones | Carno | OpenFOAM Pre-Processing | 0 | September 2, 2016 06:24 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 03:55 |
