[Other] Interface dynamic refine mesh of multi-phase fluid
Old   July 20, 2018, 14:09
Exclamation Interface dynamic refine mesh of multi-phase fluid
BAI FAN
ethanboem is on a distinguished road
I'm new to OpenFOAM, and I want to use the solver of multiphaseInterDyMFoam to refine the interface mesh of multiphase liquid. But, there is only code for refining one phase of the liquid interface in OpenFOAM (showing as below).
dynamicFvMesh dynamicRefineFvMesh;
   dynamicRefineFvMeshCoeffs
       refineInterval 1;
       field alpha1;
       lowerRefineLevel 0.001;
       upperRefineLevel 0.999;
       unrefineLevel 10;
       nBufferLayers 1;
       maxRefinement 2;
       maxCells 200000;
       correctFluxes (( phi none) (nHatf none) (rhoPhi none) (ghf none) );
       dumpLevel true;
If it is a three-phase system of water-oil-air, how to refine the mesh of water and oil phase surface dynamically at the same time? For any hints, I will be quite grateful.
ethanboem is offline   Reply With Quote
Old   July 26, 2018, 00:12
clapointe is on a distinguished road
What if you defined a new field that is the gradient of alpha and refine where it's high? This should get you refinement at the interface.
Caelan
clapointe is offline   Reply With Quote
dynamic mesh;, interface refinement, multiphase flow
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
