[Other] Adaptive mesh refinement - unbounded above on a scalar field
Old   July 19, 2018, 07:48
Default Adaptive mesh refinement - unbounded above on a scalar field
TCS
Thomas C. Sykes
TCS is on a distinguished road
Hi everyone, I'm looking to use the interDyMFoam solver (OF Foundation 4.1).
I have a droplet defined by the volume fraction (alpha), and I want to refine both around the droplet's interface and everywhere inside. That is, I want to refine where alpha>0.01 and not coarsen for any value above 0.01 (unbounded above).
So in the end, outside the droplet should have the original mesh, which changes (adaptively) across the interface, with the mesh inside the droplet (where alpha is around 1) having the same refinement as the interface.
Does anyone know if this is possible?
TCS is offline   Reply With Quote
Old   July 19, 2018, 08:39
anonymous
simrego is on a distinguished road
Hi!
What if you set:
lowerRefineLevel 0.001;
upperRefineLevel 5; // max should be 1 but to be sure.
It will refine if
0.001 < alpha.water < 5, so if alpha.water > 0.001
simrego is offline   Reply With Quote
Old   July 19, 2018, 08:47
TCS
Thomas C. Sykes
Originally Posted by simrego View Post
Hi!
What if you set:
It will refine if
Hi simrego, thanks for the suggestion. I tried that and it gave me the following error which I don't understand how to deal with.
PIMPLE: iteration 1
Selected 364 cells for refinement out of 2268.
Refined from 2268 to 4816 cells.
Selected 0 split points out of a possible 364.
Execution time for mesh.update() = 0.02 s
DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
smoothSolver:  Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 0
Phase-1 volume fraction = 0.130194  Min(alpha.water) = 0  Max(alpha.water) = 1
MULES: Correcting alpha.water
DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.0265856, No Iterations 2
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib64/libc.so.6"
#3  ? at tensorField.C:?
#4  ? at ??:?
#5  ? at ??:?
#6  ? at ??:?
#7  __libc_start_main in "/lib64/libc.so.6"
#8  ? at ??:?
Floating point exception (core dumped)
Old   July 19, 2018, 09:14
anonymous
There might be some other problems I think. Maybe your initial mesh is too coarse. But i'm just guessing. If it is the original dynamicRefineFvMesh (if you made no modifications in it), it should works like this without problems.
Old   July 19, 2018, 13:11
TCS
Thomas C. Sykes
There was something else. My alpha=1 region was initialised such that it was in a corner of two boundaries (walls - same or separate patches, the same thing happens). If I initialise in contact with a single boundary, or free, it works fine.
Maybe this is an issue with how dynamicRefineFvMesh works?
Old   July 19, 2018, 14:10
anonymous
I'm not sure if i understand your problem, but if you check the damBreakWithObstacle case, the alpha=1 field is also initialized in a corner and works fine.
adaptive mesh refinement, interdymfoam, multiphase, openfoam 4.1
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Mesh gets out of sync during parallel 2D adaptive mesh refinement pjohannes183 OpenFOAM Programming & Development 0 November 14, 2013 05:31
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 03:32
