[foamyMesh] foamyQuadMesh creating cells outside stl shape? |
July 18, 2018, 11:43 |
Pal Schmitt
Rep Power: 16 |
Dear All,
I started playing around with foamyQuadMesh and managed to create a good looking mesh. Unfortunately it also creates something outside the original STL shape (which is closed). Is this a bug or some sort of incompetence on my side? Any comments are much appreciated, example case is attached. I'm currently running v1806... Cheers, Pal |
January 20, 2020, 00:50 |
ChongQing
Rep Power: 6 |
I have the same problem with you. It looks like that foamyQuadMesh failed to calculate bounding box correctly.
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 02:37 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
Problems with Meshing: Collapsed Cells | Emmanuel Resch | Siemens | 1 | July 30, 2007 04:02 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 01:32 |
