[blockMesh] blockMesh seems to create internal barriers |
July 17, 2018, 09:58 |
Jeremy Dudley
Rep Power: 16 |
I am trying to create a simple structure using three blocks, to represent an inlet, main body, and outlet. When I do this the concentration of the inlet seems always to stay within the 1st block, and never to flow through to the other two blocks. I got a message that there were two internal faces, but when I view the grid (paraview or enGrid) I cannot see any internal face. Can anyone spot what I am doin gwrong?
vertices ( ( 0.0 0.0 0.0) // 0 (26.5 0.0 0.0) // 1 -- 0 - 1 defines X (26.5 17.0 0.0) // 2 -- 1 - 2 defines Y ( 0.0 17.0 0.0) // 3 -- 0 - 1 - 2 - 3 defines Z ( 0.0 0.0 0.026) // 4 (26.5 0.0 0.026) // 5 (26.5 17.0 0.026) // 6 ( 0.0 17.0 0.026) // 7 ( 0.0 0.0 4.974) // 8 (26.5 0.0 4.974) // 9 (26.5 17.0 4.974) // 10 ( 0.0 17.0 4.974) // 11 ( 0.0 0.0 5.0) // 12 (26.5 0.0 5.0) // 13 (26.5 17.0 5.0) // 14 ( 0.0 17.0 5.0) // 15 ); blocks ( hex (0 1 2 3 4 5 6 7) (20 4 4) simpleGrading (1 1 1) hex (4 5 6 7 8 9 10 11) (20 4 20) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (20 4 4) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet {type patch; faces ( (0 4 7 3)); } outlet { type patch; faces ((9 13 14 10)); } surface { type patch; faces ((12 13 14 15)); } ); mergePatchPairs (); |
[ANSYS Meshing] How to create Internal walls using Ansys meshing? | shivasluzz | ANSYS Meshing & Geometry | 1 | November 19, 2018 10:16 |
[blockMesh] Creating an internal mesh within blockMesh? | ashish.vinayak | OpenFOAM Meshing & Mesh Conversion | 4 | June 22, 2018 04:42 |
Howto create runtime variable for internal field | PositronCascade | OpenFOAM Programming & Development | 1 | January 5, 2017 07:33 |
internal face in blockMesh | rou | OpenFOAM | 0 | June 16, 2014 08:36 |
[blockMesh] Does blockMesh create mesh vertices in any particular order | brooksmoses | OpenFOAM Meshing & Mesh Conversion | 3 | December 12, 2005 21:26 |
