[snappyHexMesh] Add boundary layers on walls of a rectangular channel using SnappyHexMesh
Old   July 3, 2018, 07:13
Default Add boundary layers on walls of a rectangular channel using SnappyHexMesh
Gary is on a distinguished road
All,
I have been struggling with this issue for quite a long time.
The geometry is so simple, just a rectangular channel. Many suggestions recommended on this site have been tried but unfortunately none of them worked.
Could anybody here help me on this?
The geometry is in stl format and pasted below
solid channel_inlet
facet normal -1 0 0
outer loop
vertex 0 0.0005 -0.0005
vertex 0 -0.0005 -0.0005
vertex 0 -0.0005 0.0005
endloop
endfacet
facet normal -1 -0 -0
outer loop
vertex 0 0.0005 0.0005
endloop
endfacet
endsolid channel_inlet
solid channel_sides
facet normal 0 -1 0
outer loop
vertex 0.01 -0.0005 0.0005
endloop
endfacet
facet normal 0 -1 0
outer loop
vertex 0.01 -0.0005 -0.0005
endloop
endfacet
facet normal 0 0 -1
outer loop
endloop
endfacet
facet normal -0 -0 -1
outer loop
vertex 0.01 0.0005 -0.0005
endloop
endfacet
facet normal 0 1 0
outer loop
endloop
endfacet
facet normal 0 1 0
outer loop
vertex 0.01 0.0005 0.0005
endloop
endfacet
facet normal -0 0 1
outer loop
endloop
endfacet
facet normal 0 -0 1
outer loop
endloop
endfacet
endsolid channel_sides
solid channel_outlet
facet normal 1 0 0
outer loop
endloop
endfacet
facet normal 1 0 0
outer loop
endloop
endfacet
endsolid channel_outlet
Any sort of help will be highly appreciated.
Gary
Gary is offline   Reply With Quote
Old   July 10, 2018, 09:26
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Hi Gary,
Could you please post your snappyHexmeshDict here. It will be easy to figure out the problematic part.
Regards
mwaqas is offline   Reply With Quote
Old   July 10, 2018, 12:04
Muhammad Waqas
Hi Gary,
I received your Email. I am unable to see your reply here and any attached file. I have sent you an Email. You could send me the required files through Email.
Regards
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
