[Gmsh] No 3D Element found during gmshToFoam conversion
Old   June 19, 2018, 10:47
Default No 3D Element found during gmshToFoam conversion
Bhargav lakhlani
bhargav1195 is on a distinguished road
Hello Everyone,
I am trying to create a mesh of simple room with one inlet and one outlet in gmsh. I have created geometry using the OpenCASCADE kernel with following script
SetFactory("OpenCASCADE");
Box(1) = {0, 0, 0, 10, 10, 10};
Box(2) = {1, 1, 1, 0.1, 1, 1};
Box(3) = {9, 9, 9, 0.1, 1, 1};
Physical Surface("Inlete") = {8};
Physical Surface("Outlete") = {13};
Physical Surface("Wall") = {4, 1, 3, 2, 5, 6};
Transfinite Line "*"= 10 ;
Transfinite Surface "*" = 10;
Transfinite Volume "*"= 10;
Recombine Surface "*";
Even though a 3D mesh is generating in gmsh, when I try to convert into the OpenFOAM mesh using the gmshToFoam command, I am getting an error showing "No 3D elements found". I am a novice user of gmsh so please suggest me some solution for this.
Regards,
Bhargav
bhargav1195 is offline   Reply With Quote
Old   June 21, 2018, 10:37
Deep
deepbandivadekar is on a distinguished road
I'm not an expert and not 100% sure as I never encountered it before. But you are not defining a "Physical Volume". That could be a reason.
deepbandivadekar is offline   Reply With Quote
3d elements, gmsh, openfoam
[RapidCFD] Discussion thread on how to install and use RapidCFD newoscar OpenFOAM Community Contributions 88 May 17, 2024 10:39
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 9, 2019 00:50
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 16:11
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 11:45
missing vtf3.h BPatch.h papi.h linch OpenFOAM Installation 41 July 24, 2012 15:45
