[Gmsh] structured mesh .msh to OpenFOAM not working |
June 13, 2018, 20:14 |
Rep Power: 8 |
Hi everyone,
i made a structure mesh using GMSH and now try to import my .msh file into openFOAM. But when I process it, it seems like openfoam goes into a dead loop. My .geo file stays below. I would appreciate it if someone could tell me what's wrong with my meshing. I doubt there could be something wrong when I tried to use different surface to define the mesh. Thanks! cl1 = 10; cl2 = 0.5; Point(1) = {0, 0, 0, cl1}; Point(2) = {4304.8,0,0,cl1}; Point(3) = {4304.8,-127,0, cl1}; Point(4) = {304.8,-127,0, cl1}; Point(5) = {304.8,-76.2,0, cl1}; Point(6) = {0,-76.2,0, cl1}; Point(7) = {304.8,0,0, cl1}; Line(1) = {1, 6}; Line(2) = {5, 7}; Line(3) = {1, 7}; Line(4) = {6, 5}; Curve Loop(1) = {1, 4, 2, -3}; Plane Surface(1) = {1}; Transfinite Line{4, -3} = 76; Transfinite Line{1, 2} = 19 Using Bump 0.1; Transfinite Surface{1}; Recombine Surface{1}; Point(8) = {4304.8, -76.2, 0, cl1}; Point(9) = {340.8, 0, 0, cl1}; Point(10) = {340.8, -76.2, 0, cl1}; Point(11) = {340.8, -127, 0, cl1}; Point(12) = {4270, 0, 0, cl1}; Point(13) = {4270, -76.2, 0, cl1}; Point(14) = {4270, -127, 0, cl1}; Line(5) = {5, 4}; Line(6) = {4, 11}; Line(7) = {11, 10}; Line(8) = {10, 5}; Line(9) = {7, 9}; Line(10) = {9, 10}; Line(11) = {10, 13}; Line(12) = {13, 8}; Line(13) = {8, 2}; Line(14) = {2, 12}; Line(15) = {12, 13}; Line(16) = {13, 14}; Line(17) = {14, 3}; Line(18) = {3, 8}; Line(19) = {9, 12}; Line(20) = {14, 11}; Curve Loop(2) = {9, 10, 8, 2}; Plane Surface(2) = {2}; Transfinite Line{2} = 19 Using Bump 0.1; Transfinite Line{10} = 19 Using Progression 1.05; Transfinite Line{9, 8} = 9; Transfinite Surface{2}; Recombine Surface{2}; Curve Loop(3) = {5, 6, 7, 8}; Plane Surface(3) = {3}; Transfinite Line{6,-8} = 9 Using Progression 1.1; Transfinite Line{7} = 13 Using Progression 1.1; Transfinite Line{5} = 13; Transfinite Surface{3}; Recombine Surface{3}; Curve Loop(4) = {11, -15, -19, 10}; Plane Surface(4) = {4}; Transfinite Line{10,15} = 19 Using Progression 1.05; Transfinite Line{11,19} = 500; Transfinite Surface{4}; Recombine Surface{4}; Curve Loop(5) = {16, 20, 7, 11}; Plane Surface(5) = {5}; Transfinite Line{11,20} = 500; Transfinite Line{-16,7} = 13 Using Progression 1.1; Transfinite Surface{5}; Recombine Surface{5}; Curve Loop(6) = {13, 14, 15, 12}; Plane Surface(6) = {6}; Transfinite Line{-13,15} = 19 Using Progression 1.05; Transfinite Line{-12,14} = 9 Using Progression 1.1; Transfinite Surface{6}; Recombine Surface{6}; Curve Loop(7) = {16, 17, 18, -12}; Plane Surface(7) = {7}; Transfinite Line{-12,-17} = 9 Using Progression 1.1; Transfinite Line{-16,18} = 13 Using Progression 1.1; Transfinite Surface{7}; Recombine Surface{7}; Background Field = 5; Extrude{0,0,5}{ Surface{1,2,3,4,5,6,7}; Layers{1}; Recombine;} Physical Surface("Ein") = {29}; Physical Surface("Aus") = {139,169}; Physical Surface("upperWall") = {41,51,143,103}; Physical Surface("lowerWall") = {165, 121, 77, 73, 33}; Physical Surface("leer")= {1,2,3,4,5,6,42,64,86,108,130,152,7,174}; Physical Volume(1)= {1}; Surface Loop(1) = {42, 29, 1, 33, 41, 64, 51, 2, 86, 73, 3, 77, 108, 103, 4, 130, 121, 5, 152, 139, 6, 143, 174, 165, 7, 169}; Last edited by Oliver Meng; June 13, 2018 at 20:17. Reason: add new codes |
gmsh files |
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) | Combas | SU2 | 45 | October 16, 2024 18:26 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[Other] vtk mesh or Abaqus mesh to OpenFOAM | bigphil | OpenFOAM Meshing & Mesh Conversion | 27 | November 23, 2015 18:31 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
Structured Grid Definition | craig shores | Main CFD Forum | 3 | March 21, 2001 15:48 |
