[mesh manipulation] extrudeMesh can't find any patches
Old   June 12, 2018, 11:35
Default extrudeMesh can't find any patches
shang2 is on a distinguished road
I ran snappyHexMesh and am now trying to run extrudeMesh. However, extrudeMesh can't seem to find any of my patches. Do I have some sort of syntax error or do I just not understand how extrudeMesh works?
extrudeMeshDict (excerpt)
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      extrudeMeshDict;
// What to extrude:
//      patch   : from patch of another case ('sourceCase')
//      mesh    : as above but with original case included
//      surface : from externally read surface
//constructFrom mesh;
constructFrom patch;
//constructFrom surface;
// If construct from patch/mesh:
sourceCase ".";
sourcePatches (right);
Output:
|  \\    /   O peration     | Version:  5.x                                   |
Build  : 5.x-197d9d3bf20a
Exec   : extrudeMesh
Date   : Jun 12 2018
Time   : 10:30:43
Host   : "LAPTOP-CJTPIN3R"
PID    : 1693
I/O    : uncollated
Case   : /mnt/c/subTransfer/nozzle16/case4.base
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting extrudeModel linearNormal
Extruding from patch using model linearNormal
Not collapsing any edges after extrusion
Extruding patches 1(right) on mesh "/mnt/c/subTransfer/nozzle16/case4.base"
Adding overall 0 processor patches.
--> FOAM FATAL ERROR:
Cannot find patch boundary in the source mesh.
Valid patch names are
6
inlet
left
mirror
nozzle
outlet
right
    From function Foam::label findPatchID(const Foam::polyBoundaryMesh&, const Foam::word&)
    in file extrudeMesh.C at line 141.
FOAM exiting
shang2 is offline   Reply With Quote
Old   June 12, 2018, 11:36
Disregard, I was being an idiot.
Old   April 19, 2019, 10:10
Question
Rishikesh
mrishi is on a distinguished road
What were you doing wrong? I have the same issue.
mrishi is offline   Reply With Quote
Old   April 20, 2019, 05:49
Rishikesh
Never mind, I understand
Old   February 5, 2021, 21:42
Minglong Lu
dragon boy is on a distinguished road
I have the same issue, how to solve it?
dragon boy is offline   Reply With Quote
Old   February 26, 2021, 10:00
Jared Bland
JEBland is on a distinguished road
Double check that your point in the snappyHexMeshDict is inside the volume generated by the extrudeMesh.That fixed it for mine.
JEBland is offline   Reply With Quote
Old   February 26, 2021, 21:46
Minglong Lu
ok thank you!
extrudemesh, meshing, snappyhexmesh
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
Rotating Mesh, errors in Cyclic AMI interface WhiteW OpenFOAM 2 September 26, 2016 10:12
[foam-extend.org] Installing foam-extend 3.1 on Ubuntu 14.04 stephie OpenFOAM Installation 16 April 23, 2015 17:18
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
