[snappyHexMesh] snappyHexMesh and a couple of ideas
Old   June 12, 2018, 08:55
Default snappyHexMesh and a couple of ideas
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
I'm not an expert on meshing or anything but I've been thinking about snappy and I wonder if any of that is of any value.
First, how many cells/points are moved when snapping to surface? For example, if you have a stack of cubes and move one vertex of the topmost down by a significant amount you get a bad cell. But if you spread the movement among many cubes in the stack you limit the deformation of each cube. Does snappy do that and how deep does snapping deform cells?
Then, about the almost useless layer addition: what if instead of first snapping and then adding layers one would first offset, snap to offset surface and then extrude layers?
So to elaborate a bit more:
  1. Offset STL surface by overall thickness of all layers. If that would produce self-intersecting geometry one could either limit offset amount or create illegal geometry and then clean up after offsetting (?).
  2. Act as if the offset geometry is the original one and make all the snapping stuff on it.
  3. Extrude a single layer from snapped mesh to original surface. That would ensure all boundary cells are prismatic.
  4. Divide boundary layers to user's specifications.
What do you think of that, is it possible or any better or am I missing something?
kandelabr is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 17:02
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
