June 6, 2018, 07:35 |
internalMesh problems
Roque Belda
Rep Power: 8 |
Hello, I'm new with OpenFoam, and I need to simulate a Air Flow inside of tubular cavity to check how it behaves. So, I started with this tutorial: https://www.youtube.com/watch?v=ObsFQUiVi1U and later I tried to do the same with a solid cilinder. I have created the mesh, but when i vusualize this with paraView, it observe that the internal Mesh is a cube (and the cilinder is inside), whears in the tutorial has the shape of the objet. I attach you some images about it.
If someone could help me with this or indicate a better guide i will than her. |
June 7, 2018, 08:55 |
Rep Power: 16 |
It is usually helpful to also post the necessary files. Is it possible that you set "locationInMesh" outside of your geometry?
June 8, 2018, 11:59 |
Roque Belda
Rep Power: 8 |
I think that is it. I have tried to solve but I didn't get it. Can you give me some advice on how to get the center of my object?
Thanks for your help! In this link are all the files. https://mega.nz/#!KRJlBbyZ!ko1wm2vAR...cWb_VN_HlVfKGg |
June 8, 2018, 14:12 |
Rep Power: 16 |
IIRC the location should be somewhere inside. It does not need to be in the center.
June 11, 2018, 04:54 |
Roque Belda
Rep Power: 8 |
Thanks guys, I have managed to create the internalMesh successfully.
Now I want to simulate my final object. It is a bit more complex. So, I don't know how to obtain a surface from the solid, Is there any software to obtain this? |
June 11, 2018, 14:14 |
Rep Power: 16 |
There is a lot of information regarding preparing stl files for SHM in this forum and a video series at https://holzmann-cfd.com using Salome and blender.
internalmesh, snappyhexmesh |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
[mesh manipulation] Problems with rotational cyclic boundaries | TReviol | OpenFOAM Meshing & Mesh Conversion | 8 | July 11, 2014 04:45 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 07:44 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 06:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 12:00 |
