[mesh manipulation] Merge meshes from many regions
Old   June 6, 2018, 07:04
Default Merge meshes from many regions
Christian
Byba is on a distinguished road
Dear all,
I have different regions (f01 f03 f05 f07 f12 f14 f16 f22 f24 f31 f33 f41 f43 f52 f02 f04 f06 f11 f13 f15 f21 f23 f25 f32 f34 f42 f51 f61 coolant) with meshes and parameters defined separately. In detail, the structure of my folder is the following:
0: it contains all regions folder for time 0 that are f01 f03 f05 f07 f12 f14 f16 f22 f24 f31 f33 f41 f43 f52 f02 f04 f06 f11 f13 f15 f21 f23 f25 f32 f34 f42 f51 f61 coolant
constant: it contains all folders f01, f02,...,coolant for each region
system:
I want to merge the meshes and, more in general, the regions in order to obtain a "master region". I try to use "mergeMeshes" but I obtain errors about finding files. The last one is the following:
HTML Code:
 --> FOAM FATAL ERROR: Cannot find file "points" in directory "f01/polyMesh" in times 0 down to constant
I added "points" file into that and other folders without success.
Could you provide suggestions, please? I'm not an expert about mesh management and every advice, explanation and help are welcome
Thank you for your time.
Regards,
Christian
Byba is offline   Reply With Quote
Old   October 30, 2018, 16:02
Martin
msaravia is on a distinguished road
Hi Christian, could you solve the problem of merging? I'm trying to do the same...
msaravia is offline   Reply With Quote
Old   May 26, 2019, 04:23
Christian
Dear Martin,
I already read your reply, sorry for the late. However, I solved the problem defining my "master region" in Ansys, saved as .msh. After that, I converted the mesh in OpenFOAM using the command -cellZonesOnly.
Christian
mesh 3d, mesh merge, multiregion meshing
[ICEM] merge meshes between hexa and prism jjz2013 ANSYS Meshing & Geometry 39 February 12, 2019 11:38
Merge Meshes in parallel DominicTNC OpenFOAM 0 September 4, 2017 23:39
[ICEM] Smoothing before merge meshes FJSJ ANSYS Meshing & Geometry 0 May 20, 2013 12:30
[ICEM] Merge meshes with internal wall BrolY ANSYS Meshing & Geometry 20 February 20, 2013 11:43
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 02:18
