[Other] Scaled up 4 times problem
Old   June 4, 2018, 11:36
Post Scaled up 4 times problem
Jung da yoon
kane is on a distinguished road
Hello All.
I'm a beginner on OpenFoam. I ran Sandia D flame tutorial and got results.
But values of results are too small.
So comparison between other result is very hard.
I want to scale up the mesh 4 times.
What should i do?
This is a blockMeshDict file.
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
   (0     0                    -100)   // 0
   (3.6  -0.15717942211764708  -100)   // 1
   (3.6   0.15717942211764708  -100)   // 2
   (3.85 -0.168094659764705905 -100)   // 3
   (3.85  0.168094659764705905 -100)   // 4
   (9.1  -0.39731465035294123  -100)   // 5
   (9.1   0.39731465035294123  -100)   // 6
   (0     0                     0)     // 7
   (3.6  -0.15717942211764708   0)     // 8
   (3.6   0.15717942211764708   0)     // 9
   (3.85 -0.168094659764705905  0)     // 10
   (3.85  0.168094659764705905  0)     // 11
   (9.1  -0.39731465035294123   0)     // 12
   (9.1   0.39731465035294123   0)     // 13
   (150  -6.549142588235295     0)     // 14
   (150   6.549142588235295     0)     // 15
   (0     0                     500)   // 16
   (3.6  -0.15717942211764708   500)   // 17
   (3.6   0.15717942211764708   500)   // 18
   (3.85 -0.168094659764705905  500)   // 19
   (3.85  0.168094659764705905  500)   // 20
   (9.1  -0.39731465035294123   500)   // 21
   (9.1   0.39731465035294123   500)   // 22
   (150  -6.549142588235295     500)   // 23
   (150   6.549142588235295     500)   // 24
blocks
    hex ( 0  1  2  0  7  8  9  7)   (5  1 20)   simpleGrading (1 1 1)
    hex ( 3  5  6  4 10 12 13 11)   (5  1 20)   simpleGrading (1 1 1)
    hex ( 7  8  9  7 16 17 18 16)   (5  1 70)   simpleGrading (1 1 2)
    hex ( 8 10 11  9 17 19 20 18)   (1  1 70)   simpleGrading (1 1 2)
    hex (10 12 13 11 19 21 22 20)   (5  1 70)   simpleGrading (1 1 2)
    hex (12 14 15 13 21 23 24 22)   (60 1 70)   simpleGrading (3 1 2)
boundary
    inletCH4
        type patch;
        faces
            (1 0 0 2)
    wallOutside
        type wall;
        faces
            (14 15 24 23)
    wallTube
        type wall;
        faces
            (1 2 9 8)
            (10 11 9 8)
            (4 3 10 11)
            (5 6 13 12)
    inletPilot
        type patch;
        faces
            (5 3 4 6)
    inletAir
        type patch;
        faces
            (14 12 13 15)
    outlet
        type patch;
        faces
            (16 17 18 16)
            (17 19 20 18)
            (19 21 22 20)
            (21 22 24 23)
    axis
        type empty;
        faces
            (0 7 7 0)
            (7 16 16 7)
    frontAndBack_pos
        type wedge;
        faces
            (2 0 7 9)
            (6 4 11 13)
            (9 7 16 18)
            (11 9 18 20)
            (13 11 20 22)
            (15 13 22 24)
    frontAndBack_neg
        type wedge;
        faces
            (0 1 8 7)
            (3 5 12 10)
            (7 8 17 16)
            (8 10 19 17)
            (10 12 21 19)
            (12 14 23 21)
Any answers are okay!!
Best regards. Thank you
kane is offline   Reply With Quote
Old   June 4, 2018, 20:57
aow
Andrew O. Winter
aow is on a distinguished road
If all you want to do is increase the dimensions by a factor of 4, then you probably only need to modify 2 things in the blockMeshDict file you posted.
First of all, multiply all of the coordinate values in the vertices section by 4. Secondly, you should increase the number of cells in the blocks section, perhaps by multiplying them by 4 too.
The blocks and boundary sections shouldn't need to change since all of the vertice numbers won't change.
Also, as a suggestion, could you not simply scale the results you already obtained up to a larger size using similitude concepts somehow? I'm not familiar with the application you're studying at all seeing as I'm a water/air multiphase problem guy so if my suggestion makes no sense, then ignore it.
aow is offline   Reply With Quote
Is COMSOL Multi Physics is suitable to solve complex flow problem? steve lee COMSOL 8 January 5, 2023 03:31
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 20:41
Mesh& steptime independant: conduction-convection problem Fati1 Main CFD Forum 1 October 28, 2018 14:52
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
