[Gmsh] Gmsh - Problem with meshing CAD imported geometry
Old   June 3, 2018, 10:13
Default Gmsh - Problem with meshing CAD imported geometry
Artur's Avatar
Artur
Artur will become famous soon enough
Hi All,
I'm trying to mesh an example underwater vehicle hull with a duct using Gmsh. To do this, I created geometries in CAD (Autodesk Inventor 2016) and exported them to iges format. When I include filleted supports of the accelerating duct, the aft part of the hull does not mesh and Gmsh yield a warning:
Warning : Surface 22 consists of no elements
When I exclude the supports, everything works fine (see pictures below). I've attached the geometry and .geo files for both examples here:
https://www.dropbox.com/s/odsz78fsnm...ample.zip?dl=0
hoping someone can help me figure out what the problem is.
Note: I know in the renderings the Gmsh grids are super coarse but I tried much finer ones and nothing changes so I included the coarse ones to illustrate the point better.
Note: I am certain the geometry itself is OK as when I attempt to mesh it with Pointwise everything works fine.
Many thanks,
Artur
Artur is offline   Reply With Quote
Old   June 3, 2018, 11:57
Artur's Avatar
Artur
Hi All,
I found a solution by splitting the problematic surface twice to avoid any splines being used as an edge twice, see pictures below. This does not explain why Gmsh did not have a problem with this for the first geometry, but at least it's a valid workaround.
All the best,
Artur
[Workbench] Workbench 18.2 SpaceClaim->Mechanical geometry accuracy/tolerance problem sultzan ANSYS Meshing & Geometry 0 December 13, 2018 18:41
[Gmsh] gmsh meshing problem CHAYANIT OpenFOAM Meshing & Mesh Conversion 0 September 5, 2018 09:08
Problem Meshing Complex Geometry calaba Mesh Generation & Pre-Processing 1 July 12, 2017 07:25
CAD -> gMsh -> enGrid -> OpenFOAM Problem AlGates OpenFOAM 7 August 6, 2010 13:46
GAMBIT, CAD import, clean up geometry problem Nuray Kayakol FLUENT 1 December 30, 2007 12:43
