[snappyHexMesh] SHM mpirun rank 4, PID 0 exited on signal 9 (kill)
Old   May 24, 2018, 10:41
Default SHM mpirun rank 4, PID 0 exited on signal 9 (kill)
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Hello everyone,
I am using SHM to mesh a complex geometry. My geometry is having currently 7 Mi cells. I am required to do some further refinement. When I increased surface refinement level (3 to 4) for one particular patch, my case has crashed.
I am running with 8 cores. I have also tried with 6 cores (but of no use). My RAM is 32 GB and I am also using 32 GB swap memory. Memory status just before the crash could be seen in attachment.
Could anyone please tell me, what could be the issue. Why my machine is consuming so much memory. What could be the solution for this. Thank you
Here is the error message
[mpirun noticed that process rank 2 with PID 0 on node WS013 exited on signal 9 (Killed)]
I am using openFOAM 5x
Regards
File Type: png Screenshot from 2018-05-24 17-29-37.png (39.3 KB, 33 views)
mwaqas is offline   Reply With Quote
Old   February 29, 2024, 10:25
Default Memory Usage
Sea
SalmonPlant is on a distinguished road
I am also having this issue.
From all of my research, I understand this to be due to OF running out of memory. On all reports, increasing available memory should work. I am also having this issue; but, from what I can see from my system monitor OF isn't using more than 4% of available memory.
Is there something I am overlooking here?
Any help would be greatly appreciated.
My error message is as follows:
mpirun noticed that process rank 4 with PID 0 on node PC0 exited on signal 9 (Killed).
SalmonPlant is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
[ImmersedBoundary] About the moving immersed boundary tutorial: icoDyMIbFoam+movingCylinderInChannelIco wyldckat OpenFOAM Community Contributions 25 September 14, 2021 18:15
process rank 12 with PID 25320 on node exited on signal 9 (killed). Nitisha CONVERGE 6 September 15, 2018 01:31
rhoSimpleFoam time step continuity errors deepbandivadekar OpenFOAM Running, Solving & CFD 2 September 13, 2018 06:50
Problem with mpirun in ssh connection blttkgl OpenFOAM Running, Solving & CFD 0 April 22, 2017 07:29
