May 14, 2018, 09:53 |
foamjob exits
bret
Rep Power: 8 |
I'm trying to run foamjob per the example at https://openfoamwiki.net/index.php/SetSet, but when I enter foamJob -s setSet -constant after foamJob -s checkMesh -allTopology -allGeometry it runs but it exits with "readline>End" without entering the command prompt "Command>". The following are the last lines after listing the *Sets and cellZones:
Time = constant mesh not changed. Please type 'help', 'quit' or a set command after prompt. readline>Time = 0 mesh not changed. Please type 'help', 'quit' or a set command after prompt. readline>End How do I enter the foam job command line? Thanks |
foamjob |
[snappyHexMesh] Differences between FoamJob and mpirun | Twix00r | OpenFOAM Meshing & Mesh Conversion | 0 | October 17, 2018 19:09 |
MPIrun Problem with FoamJob Workaround | kaszt | OpenFOAM Running, Solving & CFD | 3 | October 4, 2018 12:55 |
Stop foamJob Script | eric.m.tridas | OpenFOAM | 5 | December 15, 2011 16:16 |
Problem with foamJob | mecbe2002 | OpenFOAM | 4 | May 21, 2010 13:34 |
FoamJob stderr redirection | hoogland | OpenFOAM Bugs | 0 | August 9, 2007 07:21 |
