[snappyHexMesh] Snap to the surface without surface refinement?
Old   May 10, 2018, 06:31
Question Snap to the surface without surface refinement?
Sarath
sk11 is on a distinguished road
Hey All,
I have a problem meshing a simple truncated cone surface. I want to introduce a pressure drop using the porousBafflePressure on this surface by creating Baffles using createBafflesDict. Since this BC works with cyclic patch, I think it is not possible to mesh using refinementSurface. Because it will create a patch of type wall. So I used only refinementRegions near the geometry. Will it be possible to snap the meshes to the surface, if I use only refinementRegions? Or is there any ways to mesh to the surface and change the patch type to work with porousBafflePressure?
Please find the CreateBafflesDict, SHMDict and the screenshot in attachments.
Many thanks,
Sarath
sk11 is offline   Reply With Quote
Old   May 16, 2018, 04:58
Sarath
I could refine to the surface and snap to surface by adding faceType internal; option under the patchinfo. This option considers the surface as an internal face and makes only null patches which will be deleted by snappyHexMesh by default.
porousbafflepressure, snap to surface
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
[snappyHexMesh] Battling with SnappyHexMexh Nickul OpenFOAM Meshing & Mesh Conversion 2 July 20, 2017 11:32
[snappyHexMesh] sHM refinement away from surface nholt OpenFOAM Meshing & Mesh Conversion 1 June 14, 2016 15:36
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 10:30
[snappyHexMesh] snappyHexMesh refinement regions ignored guitarbren OpenFOAM Meshing & Mesh Conversion 2 April 9, 2013 04:59
