[Gmsh] Meshing of a cone with Gmsh didn't quite work |
April 26, 2018, 09:53 |
Eric
Rep Power: 8 |
Hi there everyone,
I tried meshing a cone with more or less random dimensions to be meshed by Gmsh and couldn't quite figure out how I could get it right. I tried to have a nice cone, but one of the sides in my Gmsh looks like it is more cut up and a bit unshaped. The code I came up with looks like this: cl__1 = 1; boxdim = 1; gridsize = boxdim/10; Point(1) = {0, 0, 3, 1}; Point(2) = {0, 0, 0, 1}; Point(3) = {0, 3, 0, 1}; Point(4) = {3, 0, 0, 1}; Point(5) = {0, -3, 0, 1}; Point(6) = {-3, 0, 0, 1}; Circle(1) = {4, 2, 3}; Circle(2) = {3, 2, 6}; Circle(3) = {6, 2, 5}; Circle(4) = {5, 2, 4}; Line(6) = {1, 4}; Line(7) = {1, 3}; Line(8) = {1, 6}; Line(9) = {1, 5}; Line Loop(10) = {4, 1, 2, 3}; Plane Surface(11) = {10}; Line Loop(12) = {-9, 6, -4}; Ruled Surface(13) = {12}; Line Loop(14) = {-9, 8, 3}; Ruled Surface(15) = {14}; Line Loop(16) = {-6, 7, -1}; Ruled Surface(17) = {16}; Line Loop(18) = {8, 2, -7}; Ruled Surface(19) = {18}; If anyone has an idea what went wrong I'd very much appreciate it. I tried looking at the other ones which worked and the base arc line is always at the end, I tried rewritting it in such a way, but didn't lead to the desired outcome either... As said, help is much apprecaited. Thanks, Eric |
April 30, 2018, 05:24 |
Eric
Rep Power: 8 |
I realised I should have probably specified it a bit more. Below is an image of the cone I am trying to model.
somehow it doesn't work to embed the picture on this page so please follow the link... just realised that I wouldn't click that link either... damn! How can I upload it properly? https://ibb.co/dcrA8c |
April 30, 2018, 09:15 |
Mikko
Rep Power: 13 |
Hi Eric,
I would create a line and revolve it to create a cone. Here is an example script: Code:
Point(1) = {0, 0, 1, 0.01}; Point(2) = {0.2, 0, 0, 0.1}; Line(1) = {1, 2}; Extrude {{0, 0, 1}, {0, 0, 0}, Pi} {Line{1};} // Axis direction, coordinate of an axis point, angle in radians |
May 1, 2018, 21:42 |
Eric
Rep Power: 8 |
Thanks Mikko for your response, I tried using your approach yesterday, but couldn't quite figure out how to revolve the cone and generate the surface. I'll look into it again tonight.
Do you have any idea why my approach didn't work by any chance? Regards, Eric |
May 2, 2018, 16:45 |
Mikko
Rep Power: 13 |
The script should be complete. The extrude command is revolving the line and creates a segment of cone's lateral surface.
cone, gmsh |
[ANSYS Meshing] Face Meshing Doesn't Work | ordinary | ANSYS Meshing & Geometry | 0 | November 4, 2017 09:20 |
[Gmsh] GMSH: Meshing a cylinder with a HUGE number of points | HelplessWanderer | OpenFOAM Meshing & Mesh Conversion | 1 | August 10, 2017 14:17 |
[Gmsh] Extruded Meshing fails (Linear search / could not find extruded vertex) | Ijazu | OpenFOAM Meshing & Mesh Conversion | 1 | March 18, 2015 07:15 |
[Gmsh] Gmsh 3d meshing problem | rafamusura | OpenFOAM Meshing & Mesh Conversion | 2 | March 20, 2013 04:31 |
[GAMBIT] 3D hollow cone spray meshing problem | adsl17754 | ANSYS Meshing & Geometry | 3 | April 13, 2012 22:56 |
