[snappyHexMesh] surfaceCheck detects all faces as problem faces |
April 18, 2018, 04:51 |
Sebastian Vetter
Rep Power: 9 |
Hello all,
I am trying to create a mesh using snappyHexMesh but I'm not really satisfied with the results. Therefore I used the surfaceCheck function to check the stl files I am using. And there are indeed problems with them because it says "surface is not closed because not all edges are connected to two faces". When I visualize the problemFaces in paraview with surfaceSubset function I get my original geometry. So it looks like the whole geometry has a flaw but I don't know why. Did anyone have the same problem at some time and some help for me? Greetings, Sebastian |
April 18, 2018, 05:48 |
Anton Kidess
Rep Power: 30 |
Make a new, proper STL or try fixing it with the surfaceHookup utility.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
April 18, 2018, 07:40 |
Sebastian Vetter
Rep Power: 9 |
Thanks for your answer!
But what makes a proper Stl file? I exported it in relatively high resolution from ptc creo, parted it with blender in different parts like inlet, outlet etc. And further refined the stl mesh. What could I have done so that it‘s not a proper stl file? |
May 6, 2019, 03:32 |
Brett
Rep Power: 14 |
I'm having a similar problem to Seb.
All my geometry is connected, I know this because I set it up that way in Fusion 360. When I run surfaceCheck it says its not all connected, yet the simulation works ok? |
August 23, 2020, 11:43 |
TWB
Rep Power: 19 |
Hi, I think you can try 3D builder in the windows store. It's a 1 click repair which works for my case. Note that your output may be shifted after that, if it lies in the negative coordinates.
open foam, snappy hex mesh, surfacecheck |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 17:45 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 04:58 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 09:14 |
