[snappyHexMesh] snappyHexMesh error
Old   March 28, 2018, 20:03
Default snappyHexMesh error
Ishan Anjikar
ianjikar is on a distinguished road
Can someone guide me what kind of error is this? I have used the file from a tutorial and just changed the names of .stl file.
ianjikar is offline   Reply With Quote
Old   April 1, 2018, 23:36
Antimony is on a distinguished road
As the error message says, you are missing the keyword "castellatedMeshControls"
If you are reusing an old snappyHexMeshDict, then the likely cause is that you have missed a ; or ) or } somewhere.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   April 3, 2018, 21:37
Ishan Anjikar
Originally Posted by Antimony View Post
Hope this helps.
Cheers,
Antimony
Hi Antimony,
Thanks for the reply. I checked the file for brackets, but there is no open brackets.
Old   April 3, 2018, 22:29
Can you post your snappyHexMeshDict then? Becomes difficult to troubleshoot otherwise...
Cheers,
Antimony
Old   April 4, 2018, 01:08
Ishan Anjikar
I have just changed the stl file names in snappyHexMesh dict file
Old   April 4, 2018, 01:30
Ishan Anjikar
Inlet.stl, outlet.stl and sides.stl are boundaries of 50.stl. 50.stl is the internal porous volume.
snappyhexmesh, snappyhexmeshdict
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
