[Other] Why rotate-angle option doesn't exist in transformPoints utility
Old   March 26, 2018, 11:19
Default Why rotate-angle option doesn't exist in transformPoints utility
anon_q is on a distinguished road
Hello, In OpenFOAM1712 documentation of transformPoints utility, there is an option:
rotate-angle (vector Angle)
I wonder why this doesn't exist in OpenFOAM 5.x version as well?
Any ideas?
anon_q is offline   Reply With Quote
Old   April 3, 2018, 04:12
Ardalan
Ardali is on a distinguished road
You can use -rotate (vector vector) instead.
You have that option only in extended versions.
Ardalan
Ardali is offline   Reply With Quote
openfoam 1712, openfoam 5.x
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Radiation interface hinca CFX 15 January 26, 2014 18:11
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
