[blockMesh] Cavity with Internal Solid Cylinder
Old   March 21, 2018, 17:15
Default Cavity with Internal Solid Cylinder
mucgoo is on a distinguished road
I'm modelling a water filled cavity with a heated central cylinder.
I've created geometry as shown below
I've done this by creating the outer cavity, and then an inner cylinder block.
|  \\    /   O peration     | Version:  3.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
   	(0 0 0)
    (1 0 0)
    (1 0.5 0)
    (0 0.5 0)
    (0 0 1)
    (1 0 1)
    (1 .5 1)
    (0 0.5 1)
	(0.40454 0.022 0.40454)
	(0.59546 0.022 0.40454)
	(0.59546 0.478 0.40454)
	(0.40454 0.478 0.40454)
	(0.40454 0.022 0.59546)
	(0.59546 0.022 0.59546)
	(0.59546 0.478 0.59546)
	(0.40454 0.478 0.59546)
geometry
blocks
    hex (0 1 2 3 4 5 6 7) (50 50 50)
    simpleGrading
        1
        1
        1
	hex (8 9 10 11 12 13 14 15) (10 10 10)
    simpleGrading
        1
        1
        1
edges
	arc 8 9 (0.5 0.022 0.365)
	arc 10 11 (0.5 0.478 0.365)
	arc 9 13 (0.635 0.022 0.5)
	arc 10 14 (0.635 0.478 0.5)
	arc 13 12 (0.5 0.022 0.635)
	arc 14 15 (0.5 0.478 0.635)
	arc 12 8 (0.365 0.022 0.5)
	arc 15 11 (0.365 0.478 0.5)
boundary
  defaultFaces
        type wall;
        faces
            (9 13 14 10)
            (13 14 15 12)
            (12 8 11 15)
            (8 9 10 11)
            (8 9 13 12)
            (11 10 14 15)
  fixedWalls
        type wall;
        faces
            (0 3 2 1)
            (4 5 6 7)
    leftWall
        type wall;
        faces
            (0 4 7 3)
    rightWall
        type wall;
        faces
            (1 2 6 5)
    front
        type cyclic;
        neighbourPatch back;
        faces
            (0 1 5 4)
    back
        type cyclic;
        neighbourPatch front;
        faces
            (2 3 7 6)
mergePatchPairs
I've then specified the cylinder wall temperature as uniform. However, only the interior of the cylinder heats, and not the surrounding cavity.
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 293.15;
boundaryField
    defaultFaces
		type            fixedValue;
        value           uniform 353.15;
	leftWall
        type            zeroGradient;
    rightWall
        type            zeroGradient;
    fixedWalls
        type            zeroGradient;
    front
        type            zeroGradient;
    back
        type            zeroGradient;
How do I get the exterior of the cylinder to interact, or is there a better way of going about this?
mucgoo is offline   Reply With Quote
Old   March 22, 2018, 01:34
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You need to define the boundary between the cylinder and the surroundings as wall or patch and give boundary conditions.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 22, 2018, 05:17
Is that not done? (Poor naming but defaultFaces=the cylinder)
  defaultFaces
        type wall;
        faces
            (9 13 14 10)
            (13 14 15 12)
            (12 8 11 15)
            (8 9 10 11)
            (8 9 13 12)
            (11 10 14 15)
boundaryField
    defaultFaces
		type            fixedValue;
Old   March 22, 2018, 06:16
piu58's Avatar
Uwe Pilz
I don't recommend to use defaultFaces. Give the boundary a name and set the condition. Then you know for sure everything is ok.
Uwe Pilz
Old   March 22, 2018, 09:34
I've changed the face name to "Core" for all boundary conditions but the problem remains.
The interior wall of the Cylinder is heating the internal volume (I don't care what happens in this space), while the exterior isn't heating the surrounding air filled cavity.
Old   March 22, 2018, 09:44
piu58's Avatar
Uwe Pilz
Now I understand.
A patch has only one direction, because the other side is thought to be the boundary of the domain to be computed. To define it for two adjacent regions you have to note the patches twice, with an alternativ counting of nodes.
Uwe Pilz
Old   March 22, 2018, 09:52
So how do I reverse the direction so the cylinder becomes outward facing, and computation occurs between the cavity/cylinder.
Thank you very much for your help so far!
Old   March 22, 2018, 12:24
piu58's Avatar
Uwe Pilz
If you don't need the region inside the cylinder you should not mesh it but let it empty.
Uwe Pilz
Old   March 23, 2018, 06:10
That result in a blockMesh error?
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM FATAL ERROR:
face 0 in patch 0 does not have neighbour cell face: 4(9 13 14 10)
    From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 124.
[ANSYS Meshing] Meshing solid cylinder Sunlight311 ANSYS Meshing & Geometry 0 September 30, 2018 14:32
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 17:16
Help in Meshing Solid Cylinder in Gambit. Andy Singh FLUENT 5 August 31, 2004 08:31
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
Heating of a solid cylinder with internal heat generation Sriram Popuri Main CFD Forum 6 July 13, 1999 19:09
