[blockMesh] Hole in a cylinder / T-junction of two cylinders using blockMesh
Old   February 26, 2018, 13:12
Default Hole in a cylinder / T-junction of two cylinders using blockMesh
Anurag
anuragm is on a distinguished road
Hi everyone,
I am trying to using blockMesh to create a simple 3D cylinder with a hole in one of the curved sides. The final geometry/mesh would be more complicated but this is a starting point. The aim is to have two cylinders, with one continuing through another at a 90° angle. But I think this point of intersection is where I would face the most problem. I tried it and have a 2D model already but I could not wrap my head around how to achieve this in 3D.
Is there a tutorial/example that does this? If not, what would be a good way to approach this problem?
I have attached a 2-D representation of my geometry as well!
Thanks in advance!
anuragm is offline   Reply With Quote
Old   February 26, 2018, 21:31
Antimony is on a distinguished road
Personally, looking at your geometry, I think blockMesh will probably not be the most suitable one for you.
I assume you can generate the CAD model. If so, snappyHexMesh would be a much better tool for you (than blockMesh) especially since you are dealing with complicated shapes.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   February 27, 2018, 03:07
Anurag
Hi, Thanks for your reply.
I had come to the same conclusion myself but there was still a bit of uncertainty in my mind. So thanks for confirming that blockMesh is not the right tool for this job. I have made a STL geometry (but its not perfect as I made it using ICEM), and I tried to generate a mesh using cfMesh but there is no possibility of using O-grid in cfMesh. I am re-doing the geometry using Salome now, and will try the same process with snappyHexMesh.
Old   March 2, 2018, 02:14
I was looking through blockMesh again (searching for something else) when I noticed that the newer version (OF 5) has been updated to handle cylinders and spheres (point projection) which might be of use to you...
Check out section 5.3.3: https://cfd.direct/openfoam/user-guide/blockmesh/
Cheers,
Antimony
Old   March 2, 2018, 09:36
Anurag
Originally Posted by Antimony View Post
Cheers,
Antimony
Thanks for this information. This looks interesting, indeed!
This is quite new for me & I am just thinking out loud at the moment but perhaps I could project 3 vertices from the angular pipe onto the cylinder body and then define an arc using them. This has to be done for each outer O-grid block, right? I will look into it this weekend.
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 03:19
[blockMesh] How to create a T-junction cylinder with blockMesh Blanca OpenFOAM Meshing & Mesh Conversion 1 February 24, 2018 07:24
[blockMesh] OpenFOAM- Problem with BlockMesh of Cylinder NightWing OpenFOAM Meshing & Mesh Conversion 0 December 7, 2015 08:04
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Cutting a hole in the engine cylinder head in KIVA CWL Main CFD Forum 6 January 7, 2010 07:37
