[snappyHexMesh] snappyHexMesh issue on parallel meshing |
February 20, 2018, 14:08 |
Dear FOAMers,
just encountered an issue when running snappyHex in parallel, please check and image attached. The artifacts appear when I have added the layers and mesh distortion location is aligned with processor boundaries.Mesh_4cpus.png
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
February 20, 2018, 18:27 |
Beg you pardon guys, the issue was about medial smoothing, by default it goes all way away from corners and made such a fancy patterns in my mesh. The solution is one line:
// To avoid distortion nMedialAxisIter 10 https://www.openfoam.com/documentati...sh-layers.html My next step will be to use some other solver for smoothing displacements, but I will need newer version than OF4
medial, parallel, snappyhexmesh |
[ANSYS Meshing] Cant get parallel meshing to work in V18.2 | jones007 | ANSYS Meshing & Geometry | 17 | November 9, 2020 06:56 |
snappyHexMesh in parallel leads to segmentation fault | ChrisHa | OpenFOAM Pre-Processing | 1 | January 14, 2019 11:04 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
snappyHexMesh in parallel with AMI | louisgag | OpenFOAM Pre-Processing | 8 | September 15, 2014 03:57 |
[snappyHexMesh] Parallel mesh generation using snappyHexMesh | aki_yafuji | OpenFOAM Meshing & Mesh Conversion | 0 | December 25, 2010 04:49 |
