[snappyHexMesh] how to define node's on edge in snappyhexmesh?
Old   February 17, 2018, 16:59
Default how to define node's on edge in snappyhexmesh?
arash
handicraft is on a distinguished road
hi
I wanted to know is there a way, like the Gambit, that set up SnappyHexMesh to set a certain number of nodes an edge of the geometry? That is to divide the edge into segments with a certain distance?
I know that there is no direct way.
so I tried to set parameters like features/levels, refinementSurfaces/levels, refinementRegions. but Due to several parameters on this mesh affected this section and I could not find the right solution for dividing one side into the number of different parts.
and sorry for my very bad language
thanks.
handicraft is offline   Reply With Quote
Old   October 19, 2018, 20:39
Anonymous
backscatter is on a distinguished road
Originally Posted by handicraft View Post
hi
thanks.
Hi handicraft,
Did you find anything specific to setting the nodes along an edge in snappyhexmesh?
backscatter is offline   Reply With Quote
meshing 3d, openfaom, snappy, snappyhex, snappyhexmesh
[snappyHexMesh] snappyHexMesh: Feature snapping of thin membrane edge gooofy OpenFOAM Meshing & Mesh Conversion 7 September 19, 2016 05:29
[ICEM] Very weird, pre-mesh does not generate volume mesh after setting nodes on some edge. sharonyue ANSYS Meshing & Geometry 0 April 30, 2015 13:06
UDF carbon conversion papteo Fluent UDF and Scheme Programming 1 August 18, 2011 08:32
