February 7, 2018, 09:36 |
mesh independence
Hi Foamers,
in order to perform a mesh independence study, it is mandatory to use two meshes at least with different spacing, then compare one field or more through the different grids. my questions is how to get the values of a specific field at a specific point in the two grids specially if the grids are not halved/doubled (ex: h2/h1 =1.5). thanks, |
February 26, 2018, 05:39 |
#2 | |
Anurag
Rep Power: 12 |
Or perhaps you could look into a more sophisticated method like the Richardson method https://www.grc.nasa.gov/www/wind/va.../spatconv.html |
Transient mode simulation (VoF model) mesh independence study problem | yulu | FLUENT | 4 | September 20, 2016 17:30 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Mesh Independence - Valid Strategy? | Ianto | Main CFD Forum | 2 | August 31, 2009 04:36 |
