[snappyHexMesh] SnappyHexMesh layer addition iteration
Old   January 18, 2018, 11:21
Default SnappyHexMesh layer addition iteration
jazbin_hyper is on a distinguished road
Hello
Which parameter in snappyHexMeshdict controls the number of layer addition iterations? I would like to set the numbers of iterations to 1, because i'm only interested in 100% layer coverage and if the layers are not grown in first iterations, then the coverage is always smaller.
Thanks
Bojan
jazbin_hyper is offline   Reply With Quote
Old   January 22, 2018, 19:11
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
It should be the nRelaxIter parameter in the layer subdict. I am not sure right now. However, the numerical cells could be everything else than good, but I guess you know that.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
layer addition, snappyhexmesh
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 08:05
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
[snappyHexMesh] snappyHexMesh Parallel bad size error andrewpomeroy OpenFOAM Meshing & Mesh Conversion 2 April 2, 2018 02:08
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
