January 10, 2018, 02:25 |
AddLayers problem in SHM
#1 | ||
Cab
Rep Power: 10 |
Hi Foamers!
I'm traing to mesh the geometry with SHM. I have made the mesh with parts, first i do Castelled and after Snapping and i have no problem with the mesh (I have obtained a good) mesh. The problem is when i tried to do the final process, addLayers. I try to change all the parameters but always get illegal faces. For example, in my final simulation: Quote:
January 30, 2018, 08:56 |
Rep Power: 11 |
Without knowing your case I would recommend you to give cfMesh a shot. It seems to be a bit more rewarding in case of generating boundary-layer meshes. It's also not as complicated to set up a mesh generation file (meshDict).
I always struggled with SHM on complex geometries as it was simply not able to deliver a decent mesh, so I turned to cfMesh. I still experience some issues in my cases but for moderately complex or simple geometry it should serve you just fine. |
Heat Transfert, mixing problem | Wazdq | CFX | 8 | November 7, 2016 05:44 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
[snappyHexMesh] SHM add layers problem | doubtsincfd | OpenFOAM Meshing & Mesh Conversion | 0 | June 6, 2011 12:01 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
