[blockMesh] How to create a T-junction cylinder with blockMesh
Old   December 20, 2017, 13:45
Default How to create a T-junction cylinder with blockMesh
blanca
Blanca is on a distinguished road
I am trying to create a T-junction cylinder with blockMesh, but I don't know how to do it. I created first one single cylinder, so I wonder if I can mix two cylinders? Because I didn't read anything about doing it with OpenFOAM, most people did it by ANSYS or other programs.
Could anyone help me?
Thanks
Blanca is offline   Reply With Quote
Old   February 24, 2018, 07:24
Anurag
anuragm is on a distinguished road
Originally Posted by Blanca View Post
Thanks
If you are like me and prefer using open source solutions, then I can recommend gsmh which would be more than enough for what you want. However, I am not sure if it can produce structured meshes.
Incidentally, I am also trying to achieve a similar thing using blockMesh. I came across the following blockMeshDict posted by another user on this forum. It is missing O-grid in one of the blocks and I am working with this file to improve the mesh and integrating it in my geometry. However, it is a good base on which you can work as well.
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1e-2;
vertices
( 0.100000 -0.100000 0.000000)
( -0.100000 -0.100000 0.000000)
( -0.100000 0.100000 0.000000)
( 0.100000 0.100000 0.000000)
( 0.141421 -0.141421 0.000000)
( -0.141421 -0.141421 0.000000)
( -0.141421 0.141421 0.000000)
( 0.141421 0.141421 0.000000)
( 0.100000 -0.100000 1.000000)
( -0.100000 -0.100000 1.000000)
( -0.100000 0.100000 1.000000)
( 0.100000 0.100000 1.000000)
( 0.141421 -0.141421 1.000000)
( -0.141421 -0.141421 1.000000)
( -0.141421 0.141421 1.000000)
( 0.141421 0.141421 1.000000)
( 0.050000 -0.183333 0.450000)
( -0.050000 -0.183333 0.450000)
( -0.050000 -0.183333 0.550000)
( 0.050000 -0.183333 0.550000)
( 0.070711 -0.183333 0.429289)
( -0.070711 -0.183333 0.429289)
( -0.070711 -0.183333 0.570711)
( 0.070711 -0.183333 0.570711)
( 0.050000 -1.183333 0.450000)
( -0.050000 -1.183333 0.450000)
( -0.050000 -1.183333 0.550000)
( 0.050000 -1.183333 0.550000)
( 0.070711 -1.183333 0.429289)
( -0.070711 -1.183333 0.429289)
( -0.070711 -1.183333 0.570711)
( 0.070711 -1.183333 0.570711)
blocks
//block0
hex (1 0 3 2 9 8 11 10)
square
(5 5 50)
simpleGrading (1 1 1)
//block1
hex (0 4 7 3 8 12 15 11)
innerCircle
(5 5 50)
//block2
hex (3 7 6 2 11 15 14 10)
innerCircle
(5 5 50)
//block3
hex (2 6 5 1 10 14 13 9)
innerCircle
(5 5 50)
//block4
hex (1 5 4 0 9 13 12 8)
innerCircle
(5 5 50)
//block5
hex ( 17 16 19 18 25 24 27 26 )
square
(5 5 10)
//block5
hex ( 16 20 23 19 24 28 31 27 )
innerCircle
(5 5 10)
//block7
hex ( 19 23 22 18 27 31 30 26 )
innerCircle
(5 5 10)
//block8
hex ( 18 22 21 17 26 30 29 25 )
innerCircle
(5 5 10)
//block9
hex ( 17 21 20 16 25 29 28 24 )
innerCircle
(5 5 10)
edges
arc 7 4 ( 0.200000 0.000000 0.000000)
arc 4 5 ( 0.000000 -0.200000 0.000000)
arc 5 6 ( -0.200000 0.000000 0.000000)
arc 6 7 ( 0.000000 0.200000 0.000000)
arc 15 12 ( 0.200000 0.000000 1.000000)
arc 12 13 ( 0.000000 -0.200000 1.000000)
arc 13 14 ( -0.200000 0.000000 1.000000)
arc 14 15 ( 0.000000 0.200000 1.000000)
arc 3 0 ( 0.110000 0.000000 0.000000)
arc 0 1 ( 0.000000 -0.110000 0.000000)
arc 1 2 ( -0.110000 0.000000 0.000000)
arc 2 3 ( 0.000000 0.110000 0.000000)
arc 11 8 ( 0.110000 0.000000 1.000000)
arc 8 9 ( 0.000000 -0.110000 1.000000)
arc 9 10 ( -0.110000 0.000000 1.000000)
arc 10 11 ( 0.000000 0.110000 1.000000)
arc 23 20 ( 0.100000 -0.183333 0.500000)
arc 20 21 ( 0.000000 -0.183333 0.400000)
arc 21 22 ( -0.100000 -0.183333 0.500000)
arc 22 23 ( 0.000000 -0.183333 0.600000)
arc 31 28 ( 0.100000 -1.183333 0.500000)
arc 28 29 ( 0.000000 -1.183333 0.400000)
arc 29 30 ( -0.100000 -1.183333 0.500000)
arc 30 31 ( 0.000000 -1.183333 0.600000)
arc 19 16 ( 0.060000 -0.183333 0.500000)
arc 16 17 ( 0.000000 -0.183333 0.440000)
arc 17 18 ( -0.060000 -0.183333 0.500000)
arc 18 19 ( 0.000000 -0.183333 0.560000)
arc 27 24 ( 0.060000 -1.183333 0.500000)
arc 24 25 ( 0.000000 -1.183333 0.440000)
arc 25 26 ( -0.060000 -1.183333 0.500000)
arc 26 27 ( 0.000000 -1.183333 0.560000)
patches
wall
walls
(3 0 1 2)
(3 7 4 0)
(2 6 7 3)
(1 5 6 2)
(0 4 5 1)
(4 7 15 12)
(6 5 13 14)
(7 6 14 15)
( 20 23 31 28 )
( 21 20 28 29 )
( 22 21 29 30 )
( 23 22 30 31 )
patch
inlet
( 27 26 25 24 )
( 27 24 28 31 )
( 26 27 31 30 )
( 25 26 30 29 )
( 24 25 29 28 )
patch
outlet
(11 10 9 8)
(11 8 12 15)
(10 11 15 14)
(9 10 14 13)
(8 9 13 12)
patch
masterPatch
( 19 16 17 18 )
( 19 23 20 16 )
( 18 22 23 19 )
( 17 21 22 18 )
( 16 20 21 17 )
wall
mergewall
(5 4 12 13)
mergePatchPairs
(masterPatch mergewall)
anuragm is offline   Reply With Quote
[blockMesh] BlockMesh with cylinder and halfsphere ich558 OpenFOAM Meshing & Mesh Conversion 0 April 11, 2019 06:17
[DesignModeler] Urgent!!! how to create surfaces for flow inlet in a cylinder wall C.C ANSYS Meshing & Geometry 0 October 25, 2016 13:50
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 17:16
[snappyHexMesh] How to create an open cylinder using FreeCAD meng9019 OpenFOAM Meshing & Mesh Conversion 3 March 14, 2014 09:24
[snappyHexMesh] How to create a separate patch on a blockmesh surface bing.guo OpenFOAM Meshing & Mesh Conversion 0 April 24, 2011 12:35
